Really high ping tonight
- Really high ping tonight
14-09-2010 9:11 PM
Well , for the 1st time since I joined plusnet my connection seems to be a bit dodgy.
I am getting ping results on speedtest.net ranging between 100 and 220.
The most I have ever had in the 5 months or so I have been with plusnet has been 45
Its normally about 20ms.
Also my speeds have dropped a bit , never had a result below 6.3meg til tonight , just had a few that were in the 3s
Anyone else having trouble this eve?
Could any kind peeps from plusnet have a look at my line tomorrow if you get a chance. I reset the router to see if that would help but it didnt.
Cheers
Paul.
Cheers
Paul.
Message 1 of 9
(1,300 Views)
8 REPLIES 8
Re: Really high ping tonight
14-09-2010 10:27 PM
Message 2 of 9
(603 Views)
14-09-2010 11:16 PM
Ping back down to 24ms on speedtest.net now.
Speed still a bit lower that normal. Max 5.8meg instead of 6.5 but thats ok.
Message 3 of 9
(603 Views)
15-09-2010 3:49 PM
Hi paulpicks21,
Just ran a line check. Interleaving off and BT profile now 7150 so I've nudged ours a bit as it was still on 6500.
Jojo
Jojo
Message 4 of 9
(603 Views)
15-09-2010 6:18 PM
Let us know what your pings are like tonight paulpicks21?
Kelly Dorset
Ex-Broadband Service Manager
Message 5 of 9
(603 Views)
15-09-2010 7:45 PM
Getting the same here, but only on certain sites. One is Wikipedia.
Target Name: en.wikipedia.org
IP: 91.198.174.232
Date/Time: 15/09/2010 19:42:48
1 0 ms 0 ms 0 ms 0 ms 0 ms [192.168.1.1]
2 32 ms 41 ms 31 ms 40 ms 31 ms lo0-homesurf.ptn-ag01.plus.net [195.166.128.124]
3 210 ms 31 ms 30 ms 31 ms 31 ms gi2-6-605.ptn-gw01.plus.net [84.92.3.17]
4 30 ms 30 ms 31 ms 87 ms 183 ms te3-1.ptn-gw02.plus.net [212.159.1.110]
5 31 ms 30 ms 135 ms 55 ms 30 ms te2-2.pte-gw2.plus.net [212.159.1.106]
6 38 ms 38 ms 37 ms 46 ms 38 ms ten4-0.lon.leaseweb.net [195.66.225.56]
7 37 ms 39 ms 39 ms 56 ms 38 ms po100.sr1.evo.leaseweb.net [85.17.100.226]
8 38 ms 38 ms 38 ms 39 ms 39 ms te-8-4.csw1-esams.wikimedia.org [85.17.163.241]
9 37 ms 37 ms 36 ms 37 ms 37 ms text.esams.wikimedia.org [91.198.174.232]
Message 6 of 9
(603 Views)
15-09-2010 8:15 PM
Thanks looking into it and doing that Jo.
Speedtests are still showing around 5.9meg so its still a bit down on the speeds I have had , but thats fine for me.
Would I need to reset the router again since you upped my profile your end for it to take effect?
Hi Kelly , so far tonight all seems good , speedtest is showing pings of 24ms on my normal server and pinging bbc.co.uk I am getting around 20ms.
Cheers
Paul.
Cheers
Paul.
Message 7 of 9
(603 Views)
16-09-2010 8:20 AM
Well everything is looking great again this morning.
Ping 23ms
Speed 6.6meg
Must have just been a little glitch.
Cheers
Paul.
Ping 23ms
Speed 6.6meg
Cheers
Paul.
Message 8 of 9
(603 Views)
16-09-2010 10:24 AM
Glad it looks good again now Paul. That lift in the profile will have improved the speed a bit.
Jojo
Jojo
Message 9 of 9
(603 Views)
