Really Slow Broadband
- Really Slow Broadband
- « Previous
- 1
- 2
- Next »
Re: Really Slow Broadband
19-07-2017 10:51 AM
Hi again, since the weekend when this issue seemed to have been resolved, the internet connection has been dropping in and out. Every time the connection goes out it encourages me to log into to my router, after which, I am told DSL connection is down. Likewise when I click "connect" for the internet, it says could not bring up link.
19-07-2017 11:01 AM
Have you raised a fault report?
Which router are you using? If it is supported by router stats it might be helpful to establish 24x7 monitoring - see the links below.
19-07-2017 11:11 AM
Current Router Stats:
19-07-2017 11:18 AM
If you are able to set up router stats monitoring and plot the graphs, we can get a view on if REIN or line balance is or is not a concern here.
19-07-2017 11:29 AM
Ok, the monitor is set up now, I will send the results tomorrow?
19-07-2017 2:21 PM
Your connection doesn't look good.
My tests aren't identifying the cause of that. I'd recommend completing the broadband troubleshooter at http://faults.plus.net so that we can arrange an engineer to investigate further.
- « Previous
- 1
- 2
- Next »
