Really Bad Tonight
- Really Bad Tonight
Re: Really Bad Tonight
02-02-2012 7:41 PM
Quote from: Azagoth 2 23 ms 27 ms 23 ms lo0-central2.thn-ag2.plus.net [195.166.128.230]
Hey Azagoth. There is a device in the network behind that gateway that isn't happy. It's being looked at now, but if you reconnect you'll probably move onto a different gateway and get much better speeds. Give that a try.
(p.s are you on netgoth? )
Ex-Broadband Service Manager
02-02-2012 7:43 PM
Any ideas?
edit....
now connected to pcl-ag01 and we are back up to 10.9mb download which is slower than normal but perfectly acceptable
10 minutes later, it's gone again
not funny guys
02-02-2012 8:10 PM
seems OK now with no reboot.
02-02-2012 8:19 PM
02-02-2012 8:24 PM
Edit, Just fired up BF3 and I am getting no ping readings whatsoever. PSN down too, welcome to the modern age
02-02-2012 8:29 PM
Quote from: ak3dgfx We are having a terrible time today, about half the pages we try and access need a refresh, speeds are so poor they should be measured in slows, google search keeps throwing up 'the app is unreachable'. We've rebooted the router several times, currently 'connected' to pcl-ag05.
Any ideas?
edit....
not funny guys
Yeah, sorry. We are still working on it atm. Not much more I can suggest right now bar hanging in there
02-02-2012 8:33 PM
02-02-2012 8:39 PM
C:\Documents and Settings\ROB>tracert www.bbc.co.u
Tracing route to www.bbc.net.uk [212.58.244.71]
over a maximum of 30 hops:
1 42 ms 99 ms 99 ms dsldevice.lan [192
2 43 ms 41 ms 41 ms lo0-central4.thn-a
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * ^C
Line 8 you can see where I just gave up and cancelled it as it had sat like this for what seemed for ever.
02-02-2012 8:50 PM
02-02-2012 8:55 PM
02-02-2012 9:02 PM
02-02-2012 9:03 PM
02-02-2012 9:04 PM
02-02-2012 9:11 PM
Quote from: Kelly ...it is worth you guys doing a router restart if you haven't already to see if you can get on an unaffected part of the network.
That works for me Kelly - thanks!
@Brabus: either should do it - I used the menu.
02-02-2012 9:19 PM
