Re- issue in traceroute
las17
Hello
Tried to post support ticket with absolutely zero results, tried to chat online, chat won't load claims we have ad blocker, we don't !! Not going to waste time phoning so we have been investigating ourselves and notice a traceroute issue to xenaknits.com, siteground hosting can also see the issue. Can you investigate this and resolve it please.
Thank you
1 dsldevice (192.168.1.254) 3.891 ms 2.404 ms 2.257 ms
2 410.xe-2-2-0.central10.psb-bng03.plus.net (84.93.253.112) 15.201 ms 13.493 ms 13.417 ms
3 411.be7.psb-ir02.plus.net (84.93.253.119) 14.717 ms
411.be7.psb-ir01.plus.net (84.93.253.115) 14.635 ms 14.358 ms
4 195.99.125.142 (195.99.125.142) 14.965 ms 16.695 ms 14.970 ms
5 peer6-hu0-6-0-4.telehouse.ukcore.bt.net (195.99.127.13) 15.919 ms 15.338 ms 15.992 ms
6 t2c3-et-7-3-0-0.uk-lon1.eu.bt.net (166.49.211.230) 17.093 ms
t2c3-et-3-3-0-0.uk-lon1.eu.bt.net (166.49.211.238) 15.187 ms
t2c3-et-7-3-0-0.uk-lon1.eu.bt.net (166.49.211.230) 15.134 ms
7 * * *
8 * ae5.cbs02.tg01.lon01.networklayer.com (169.45.18.16) 19.268 ms 16.342 ms
9 bf.13.2da9.ip4.static.sl-reverse.com (169.45.19.191) 15.817 ms
c5.13.2da9.ip4.static.sl-reverse.com (169.45.19.197) 16.181 ms
c3.13.2da9.ip4.static.sl-reverse.com (169.45.19.195) 15.724 ms
10 75.76.32a9.ip4.static.sl-reverse.com (169.50.118.117) 15.985 ms
71.76.32a9.ip4.static.sl-reverse.com (169.50.118.113) 16.644 ms
79.76.32a9.ip4.static.sl-reverse.com (169.50.118.121) 17.186 ms
11 c3.76.32a9.ip4.static.sl-reverse.com (169.50.118.195) 17.750 ms
bd.76.32a9.ip4.static.sl-reverse.com (169.50.118.189) 17.231 ms
bb.76.32a9.ip4.static.sl-reverse.com (169.50.118.187) 16.151 ms
12 ip-77-104-171-248.siteground.com (77.104.171.248) 16.299 ms 19.753 ms 17.657 ms
1 REPLY 1
Fixes: 1,547
Re: Re- issue in traceroute
Hi there.
Apologies for the delayed response to your post and that you're having issues.
You can raise a fault ticket to us at http://faults.plus.net
Do you have third party cookies enabled on your web browser?
To my eye that traceroute looks fine, but our tests are showing a Rectified Loop (Basically a short circuit) somewhere, so I've reported this through to Openreach now and we'll update you when we know more via this ticket.
Thanks.
