Re: help with speed suddenly dropping
- Re: help with speed suddenly dropping
09-06-2014 12:36 PM
Sorry for posting here. I didn't want to start a new thread on the same issue. I have also come home today and I have dropped from 72 to 63mbps. My PN speed profile still says 75.4 but I get this.
Is it worth me rebooting the OR modem? I haven't touched it for a while. I use the same server to test ( Namesco London) which is meant to be the best one but I get it with most servers I try.
to OP - sorry to thrash your thread mate!
Cheers
09-06-2014 12:40 PM
09-06-2014 12:41 PM
I just wanted to say to the team I just did an OR modem reboot and I am struggling to get 60 now and I am on ptw-bng01
09-06-2014 1:29 PM
::edit:: something happened around 6.30am..
http://f8luresig.mouselike.org/sig.png?/53516.png
09-06-2014 1:48 PM
I've taken a look over your line and can't see any issues. It seems that interleaving may have been applied in the early hours of this morning, this is done by the DLM at the exchange.
At the moment we need to see if you line does pick back up to where it was, if it was to continue to decrease then we'd need to raise a fault for that but for now it would be worth monitoring,
09-06-2014 1:53 PM
Thanks. I did think this could be it due to the double in Pings. i'll keep an eye on it - is it possible to take it off on FTTC like it is with ADSL? I was getting little to no DC's on fastpath and that's only when I knocked a plug out (which caused my initial speed dip)
But I will give it the usual 72 hours and then see if it's picked back up. I'll also keep an eye on the MC line speed incase that chances
Thanks for taking a look
Pete
09-06-2014 2:10 PM
I created an FTTC DLM guide a few weeks back that might be of interest: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
Unfortunately we can't place orders to modify the DLM as we can on ADSL. The best bet, as you say is to wait, I would say up to a week to see if things improve. If your line stays connected and generally error free, the speeds should increase and Interleaving should remove itself.
09-06-2014 2:14 PM
Cheers for the read - interesting. .
No problem I will just let it run and see if it can stay up a week (should do) it's not the double pings that bother me it's the massive speed drop. Especially when I saw yesterday there are now a whopping 9 on our cab including me. that 64 port line card sure looks lonely.
Pete
09-06-2014 4:05 PM
Are you able please to post my line stats on here as you did with Tony? I wouldn't normally ask but I have no way of seeing them as the BTW tester as you know is broken.
Thank you
09-06-2014 9:03 PM
never mind, Who cares anyway it's unlimited.
10-06-2014 10:18 AM
10-06-2014 8:35 PM
10-06-2014 8:51 PM
10-06-2014 8:57 PM
11-06-2014 10:24 AM
"Estimated line speed: 15Mbps
Current line speed: 63Mbps"
Estimated line speed was actually 59. I am struggling to reach 56 today. so I guess someone will now say " oh your getting 56 when you were estimated 15" Which is rubbish
59Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - "
My line (apparently) is 300M but I am physically 150 from the NGA,. I can see it from here. if I had not moved up a floor in this house I would have had a totally new line. I wish I had now.
This is meant to be " real fibre" and superior to Cable - someone was clearly on something when they came up with that. - No DC's until DLM just turns on probably because the wind was blowing the wrong way and now I've lost something like 13mbps and it still seems to be dropping. last DC seems to have been around 2:30am today.
Can't even get my god dam line stats still. I might try this other AP that I have and see if that does anything. Maybe it's the technipants?
Sorry for the rant but I am stuck now in 18 months of a service that is so unstable it's laughable. It's not like I am miles from the NGA.
