Re: PPP Authentication error
- Re: PPP Authentication error
on
15-07-2017
2:23 PM
- last edited on
19-07-2017
1:08 PM
by
Mav
This has been happening to me since my connection was set up a few days ago. Randomly disconnects and the router is unable to authenticate again until I manually log into it and hit connect. The event log shows this:
"PPP LCP Send Termination Request [Failed to authenticate ourselves to peer]"
This is extremely irritating as sometimes I need to remotely access my PC, which is not possible when the router disconnects like this. The line is stable, but it appears that the Plusnet PPPOE (or RADIUS) server just keeps failing to authenticate my router correctly. Please sort this!
Moderator's note by Mike (Mav): Changed thread title after split to reflect issue.
Re: Broadband keeps dropping off
17-07-2017 10:20 AM
Sorry to hear you're having issues.
Our tests aren't showing any issues but if the drops continue we'd recommend raising a fault here
Matthew Wheeler Plusnet Help Team |
19-07-2017 1:34 AM
Does your comment above apply to the OP or the piggy-backer? I've asked the mods to split the piggy-backer off.
19-07-2017 12:59 PM
@Townman It was in response to the piggy backer
19-07-2017 1:09 PM - edited 19-07-2017 1:11 PM
Moderator's note:
Split for better visibility and title changed to reflect issue.
Forum Moderator and Customer
