Re: No response to ticket?
iarsnoo
I'm also unimpressed by the lack of a coherent response to my question on slow speeds and disconnections. In my case the question is #38001470. Basically, I'm waiting for Plusnet confirmation that they agree that I have a line problem before I contact the line provider (BT). Nearly two days have passed since I raised this.
Fixes: 58
Split off to it's own thread
Fixes: 9
Is it an audible problem that is still present when the router is disconnected? If so you don't need to wait for Plusnet to confirm.
(Dial 17070 option 2 to test it)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
iarsnoo
Thank you. I'll contact BT.
jojopillo
Hi iarsnoo,
Just to let you know, your line has been more stable over the last 12 hours than it has been for over a weekIf it stays like that then your profile will soon lift.
Jojo Smiley
Fixes: 9
But while your line continues to be noisy the speed could dive back down again at any time and there's nothing Plusnet could do to prevent it (other than putting you on a fixed rate 2MB connection).
iarsnoo
Many thanks to Jojo and jelv for comments.
I think I made a mistake by joining an existing thread with an inappropriate title, so I'm going to start a new one shortly!
Fixes: 58
If you go to the first post in this thread and click on modify you can change the title
iarsnoo
Thanks, Jim. Didn't know that, and will bear it in mind. However, on reflection, I've started a new thread as I'm going off on a different tack!
