Re: My line profile and attenuation - podman's problem
- Re: My line profile and attenuation - podman's pro...
03-02-2011 5:37 PM
Quote from: podman I am due to switch to Adsl2 on 21cn this week would making this change to snr confuse things in the system / process?
Yes, it may well do as when a regrade takes place they will often use what's called modified FTR so that you don't have quite the same 10 day training on the new service, so if it was in the middle of a training period it may cause issues.
Jojo
03-02-2011 6:38 PM
podman
04-02-2011 8:48 PM
regards,
podman
07-02-2011 11:10 AM
are you still in the test socket?
Jojo
07-02-2011 2:43 PM
podman
08-02-2011 8:56 AM
Were these last couple of drops ones you were aware of?
Jojo
08-02-2011 9:35 AM
I am aware of Fridays longer disconection. I presumed that was my change to 21cn going through. Saturdays I am not aware off and Mondays i think was my helpful son.
I have noticed my SNR has increased over the weekend it had dropped over the last week and half to 12 is now back up to 15 approx.
the short on/off blips were rebooting to get my wireless to work. and trying pppoa
podman
08-02-2011 2:43 PM
I'll get the SNR reset today but just beware that any tinkering may cause issues.
Jojo
08-02-2011 6:49 PM
you're a star.
New stats:
ADSL
Type Interleave Path
Status Show Time
Downstream Upstream
Data Rate (kbps) 6912 444
Noise Margin (dB) 5.5 27.1
Attenuation (dB) 41.4 25.3
Output power(dbm) 19.6 12.4
Thankyou very much. no more tinkering. I promise.
Podman
08-02-2011 10:57 PM
I've just ran a line test and the profile's lifted a bit to 4500, so I've upped that on our side and you should see that shortly. With that sync rate we should see a profile of 6000 soon though.
Jojo
10-02-2011 12:18 PM
My line is now sync'ed just above 7000. With 21cn does the 3 day waiting time still remain for line speed increases?
regards,
podman
10-02-2011 2:39 PM
I'll do some checks and get back to you.
Jojo
10-02-2011 2:50 PM
The sync rate I am currently 6272k but the profile is still stuck at 3500. I'll see if I can get them to check it for you.
Jojo
10-02-2011 3:36 PM
The SNR has risen again to 9 / 9.5 after two days of stable at 6 is there anymore I can do to get it to stabalise at 6. As sync was 7102 now 5920 kbps
line speeds still showing as 3.5
in master socket
podman
11-02-2011 10:26 AM
Still can't seem to unstick the profile. I'm going to reset the line so this should match everything back up. I'll let you know when you should see the difference.
Jojo
