Re: My line profile and attenuation - podman's problem
- Re: My line profile and attenuation - podman's pro...
21-01-2011 2:33 PM
I believe I had my line attentuation fixed to 9db by PN previoulsy and at that time i saw an increase in speed. My attenuation has increased to 14 and my sync speed has decreased as a result.
If Pn can still set attenuation? how do i need to speak to as the person i asked on the phone the last time said nothing could be done.
podman
21-01-2011 2:36 PM
The attenuation is a physical effect related to line length and quality
You are referring to the default noise margin where the line speed drops as the default noise margin increases
21-01-2011 3:09 PM
I maybe am confused. if there anyway that the downstream noise margin can be set then?
21-01-2011 4:12 PM
So before doing anything you need to ensure that your line is in a state where it can hold the lower noise margin.
The fact that it increased from 9dB to 15dB indicates that there is a problem and you need to sort that first.
However - as it appears that it has been reduced once that may well result in BT refusing to do it again
21-01-2011 8:15 PM
so I don't beleiev the issue is my side of the connection as there has been so many changes of equipment and I still have the lower syncs.
podman.
22-01-2011 3:56 PM
If the router loses sync often then it would suggest the problem is between there and the exchange so tell that to PN and they can get BT Openreach to look into this problem.
If however there are no problems when connected to the TEST socket then that would suggest that there is an issue with your internal phone wiring and/or extensions.
All this depends on the router and micro filters all being in good working order.
Line stats explanation from the KITZ website.
25-01-2011 9:05 AM
Have you had any better results in the test socket?
Jojo
28-01-2011 9:08 PM
On checking on kitz site today using the line length calculator it estimates roughly the same but when I use the 21cn speed calculator putting in the current Downstream Attn at 43 my line length is estimated as over 3km.
Could it be that my line has at some point been swapped to a longer one without my knowledge, which would explain why my sync speed has dropped from previous 8128kbps to never really going above 5000kbps, or could it be my line has deteriorated to cause the change.
is there a feasible way to get it swapped back to a shorter line or would I have to own bt first.
28-01-2011 9:41 PM
http://community.plus.net/forum/index.php/topic,25505.32.html
podman
View Profile EmailPersonal Message (Offline)
« Reply #37 on 13/05/2006, 16:02 »
Starts at present are:
DSL Status : Up
DSL Modulation Mode : GDMT
DSL Path Mode : FAST
Downstream Rate : 7552 Kbps
Upstream Rate : 448 Kbps
Downstream Margin : 5 db
Upstream Margin : 25 db
Downstream Line Attenuation : 46
Upstream Line Attenuation : 24
Downstream Transmit Power : 0
Upstream Transmit Power : 0
My line speed has stabalised at 7000kbps and Plusnet agree that I'm on the incorrect profile as my downaload speeds are at or bwloew 2mb. I have raised a ticked to get my profile changed so here'e hoping it will happen soon.
There was talk elsewhere on the forums of pl;usnet fixing this problem over a 48hr period from the 9th on obviuosly my account wasn't included.
Looking forward to seeing the difference.
A
also here so it really is not my imagination my line used to be so much better.
« Reply #67 on 25/05/2006, 20:35 »
Here is a list of my line stats (see below) why do these still vary so drastically from my download speeds. I was maxed on 3rd May thuogh I have still to recieve a mail from plusnet telling me of this change, reading earlier post could that be the problem?
Are these results the same as everyone else. Do we really believe BT that it'll all be fixed by the time the bulk upgrade tool is re-introduced on 6th June?
I'm not moaning here just asking what everyone elses stats and spped are.
Cheers
A
DSL Status : Up
Downstream Rate : 8000 Kbps
Downstream Margin : 3 db
Upstream Margin : 23 db
Is there anything i can do to get it back to tip top performace. In the master socket no extensions. Downstream noise margin appears to be the main difference in the stats.
Todays stats for comparison. 21:44. 28th Jan 2011
ADSL
Type Fast Path
Status Show Time
Downstream Upstream
Data Rate (kbps) 5024 448
Noise Margin (dB) 12.0 25.0
Attenuation (dB) 43.2 21.0
Output power(dbm) 19.4 12.1
28-01-2011 11:41 PM
Each 3dB increase in target noise margin typically reduces sync speeds by 500 to 800kbps. So 6dB's worth is 1000 to 1600kbps which goes a long way towards accounting for the difference in sync speeds between you old stats and the current ones.
29-01-2011 7:39 AM
cheers podman
29-01-2011 2:10 PM
29-01-2011 9:44 PM
podman
30-01-2011 5:00 PM
Statistics -- ATM
ATM Interface Statistics
In Octets: 1680528
Out Octets: 188016
In Errors: 0
In Unknown: 0
In Hec Errors: 0
In Invalid Vpi Vci Errors: 0
In Port Not Enable Errors: 0
In PTI Errors: 0
In Idle Cells: 0
In Circuit Type Errors: 0
In OAM RM CRC Errors: 0
In GFC Errors: 0
AAL5 Interface Statistics
In Octets: 1680528
Out Octets: 188016
In Ucast Pkts: 1567
Out Ucast Pkts: 1149
In Errors: 1
Out Errors: 0
In Discards: 0
Out Discards: 0
AAL5 VCC Statistics
CRC Errors: 1
SAR Timeouts: 0
Oversized SDUs: 0
Short Packet Errors: 0
Length Errors: 0
is it possible to request the snr to be test to 6 or 9 before my change to 21cn?
30-01-2011 10:48 PM
