Re: Is it possible to test line speed?
- Re: Re: Is it possible to test line speed?
07-02-2014 6:53 PM
sorry to be a bit off topic here, but 1.6Mbs seems very low for FTTC. My estimated speed from Plusnet was 76Mbs. I have had FTTC since 2010 and my speedtest.net speeds have been consistently in the 38Mbs range.
Am I looking at the wrong figures?
Message 1 of 6
(773 Views)
5 REPLIES 5
07-02-2014 7:05 PM
Mod note.
Post split off to it's own topic.
Message 2 of 6
(478 Views)
07-02-2014 7:10 PM
Yeah... thanks.....
My question above relates to someone posting their FTTC estimate is 1.6Mbs. I'm wondering whether I am looking at different results because my ADSL speed was better than that before I migrated to the FTTC platform.
Message 3 of 6
(478 Views)
07-02-2014 7:40 PM
ADSL is affected by your distance from the exchange, FTTC is affected by your distance from the cabinet sometimes the two have no bearing on each other.
Message 4 of 6
(478 Views)
07-02-2014 8:45 PM
Hi dvorak
Thanks for the reply. Would you be able to expand on what you mean by the trial? I will try anything to get a faster more usable speed.
Message 5 of 6
(478 Views)
07-02-2014 8:58 PM
Please run the Bt speedtest
This explains http://community.plus.net/forum/index.php/topic,96155.0.html
Message 6 of 6
(478 Views)
