Re: How accurate is the status info shown on BT 2110 Router re Line mode?
- Re: How accurate is the status info shown on BT 21...
10-05-2012 7:21 PM
Hi JoJo,
I'm back on my fixed line now, looks like the broadband came up around 18:00 today.
Router indicates still on ADSL(1) i.e. see stats below - but also my D/L speed has dropped from 960 to 544 whilst my U/L speed has gone up from 512 to 544
router stats at 19:20 today :-
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:01:09:57
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 544 Kbps 544 Kbps
Noise Margin 7.6 dB 10.0 dB
Line Attenuation 63.5 dB 31.5 dB
Output Power 15.8 dBm 12.6 dBm
K (number of bytes in DMT frame) 18 18
R (number of check bytes in RS code word) 16 8
S (RS code word size in DMT frame) 8 8
D (interleaver depth) 4 4
Super Frames 246913 246911
Super Frame Errors 55 0
RS Words 2098768 2098743
RS Correctable Errors 4451 12
RS Uncorrectable Errors 171 0
HEC Errors 48 0
OCD Errors 1 0
LCD Errors 0 0
ES Errors 0 0
Any ideas what is going on?
Ian
HEC Errors 48 0
OCD Errors 1 0
LCD Errors 0 0
ES Errors 0 0
Ian
Message 1 of 5
(1,044 Views)
4 REPLIES 4
Line down this morning is this ADSL2+??
11-05-2012 8:15 AM
Hi JoJo,
I'm starting a new thread since my postings in the original thread
"How accurate is the status info shown on BT 2110 Router re Line mode?" don't appear to be picked up (see my last three postings in that thread).
MY BB line is now down completely i.e no DSL or Internet indicators I have reset the router this morning but no change.
I wont be back in till after lunch today but would appreciate a update from you or should I report this as a fault?
Ian
Ian
Message 2 of 5
(421 Views)
Re: Line down this morning is this ADSL2+??
11-05-2012 8:18 AM
If you're line is down, I'd always recommend raising a fault first, someone on hand 24 hours to get things going at the call centre.
Message 3 of 5
(421 Views)
11-05-2012 9:22 AM
Hi dvvrue95,
As dvorak says we'd advise you to raise a fault. Please either update ticket 54696636 or give our support guys a call on 0800 432 0200.
Let us know if you have any difficulties beyond that.
Message 4 of 5
(421 Views)
11-05-2012 2:03 PM
Hi guys returned home, thanks for the feedback.
Line was (still) down did a router power off/on and synced up OK. Spoke briefly to support about yesterdays problems which seem to be a bit of a mystery. Still have agreed to leave everything as is to allow line to stabilize. Just for the record stats now :-
Latency Type Interleave Line Up Time 00:00:17:16
Line Rate 1024 Kbps 512 Kbps
Noise Margin 5.4 dB 10.0 dB
Output Power 16.7 dBm 12.6 dBm
K (number of bytes in DMT frame) 33 17
R (number of check bytes in RS code word) 16 16
S (RS code word size in DMT frame) 4 8
D (interleaver depth) 8 4
Super Frames 60946 60944
Super Frame Errors 1 0
RS Words 1036086 518024
RS Correctable Errors 16882 26
RS Uncorrectable Errors 8 0
HEC Errors 1 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
will be in touch in due course, Ian
HEC Errors 1 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
Message 5 of 5
(421 Views)
