Re: DNS weirdness
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
OK in a DOS window as you would normally do a tracert do this command Tracert 74.52.180.187
and it starts off like this
C:\Users\James>tracert 74.52.180.187
Tracing route to bb.b4.344a.static.theplanet.com [74.52.180.187] which isn't the name of your site
The IP address of the site is the one which the DNS servers show on the Tracert command
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
To change the DNS servers on the Belkin to OpenDNS go here https://www.opendns.com/start/device/belkin
gprit
Re: DNS weirdness
This is what I got this time.....(which I have had before).....although I often get the message as per my original post for tracert.
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Graham Pritchard>tracert 74.52.180.187
over a maximum of 30 hops:
  1    2 ms    1 ms    1 ms  192.168.2.1
  2    44 ms    35 ms    37 ms  lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
  3    40 ms    35 ms    37 ms  gi2-2-204.ptn-gw02.plus.net [84.92.3.93]
  4  188 ms  220 ms  210 ms  te2-2.pte-gw2.plus.net [212.159.1.106]
  5    36 ms    38 ms    35 ms  80.239.193.141
  6    47 ms    54 ms    39 ms  ldn-bb1-link.telia.net [80.91.248.90]
  7    36 ms    73 ms    55 ms  ldn-b3-link.telia.net [80.91.249.170]
  8    36 ms    35 ms    40 ms  abovenet-ic-126798-ldn-b3.c.telia.net [213.248.1
01.106]
  9    42 ms    44 ms    37 ms  so-0-0-0.mpr1.lhr2.uk.above.net [64.125.27.225]
10  126 ms  137 ms  127 ms  so-0-1-0.mpr1.dca2.us.above.net [64.125.27.57]
11  145 ms  158 ms  150 ms  ge-2-0-0.mpr3.iah1.us.above.net [64.125.25.114]
12  157 ms  146 ms  161 ms  xe-1-1-0.er1.iah1.above.net [64.125.26.222]
13  166 ms  145 ms  143 ms  209.66.99.94.available.above.net [209.66.99.94]
14  141 ms  154 ms  143 ms  et5-4.ibr04.dllstx3.theplanet.com [70.87.253.53]
15  141 ms  144 ms  144 ms  te9-2.dsr01.dllstx3.theplanet.com [70.87.253.14]
16    *        *        *    Request timed out.
17  149 ms  142 ms  149 ms  po1.car03.dllstx6.theplanet.com [70.87.254.154]
18  151 ms  142 ms  156 ms  bb.b4.344a.static.theplanet.com [74.52.180.187]
Trace complete.
gprit
Re: DNS weirdness
This is what I got......(and have had previously at times) although often it is as per my original post....
01.106]
Trace complete.
Nocturne
Re: DNS weirdness
I can bring up all sites I've tried but cannot bring up Plusnet Portal ie Log in page.
Is this possibly the same issue being raised here or likely to be something else ?.
gprit
Re: DNS weirdness
My instinct tell me it the same issue that's been discussed on PlusNet and supposedly fixed.  I get pretty dismal support direct from plusnet. If noit fixed in the next 2/3 days I shall have to leave.
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
Why don't you switch to OpenDNS as I suggested https://www.opendns.com/start/device/belkin
Nocturne
Re: DNS weirdness
Thanks Oldjim
Tried the link and I've now found the second site I can't bring up.
gprit
Re: DNS weirdness
Opendns......I'll have a read through this.....but in essence what does it doe/acheive???!
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
It means that you aren't using the Plusnet DNS servers.
The DNS servers are the thing which converts your web site name to a number the internet can understand
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
Quote from: Nocturne
Thanks Oldjim
if you can advise your router I will post the details of how to apply it
HPsauce
Re: DNS weirdness
Quote from: gprit
It's the Internet equivalent of Directory Enquiries.
So you're changing from (say) 118 118 to 118 500 for example.
Nocturne
Re: DNS weirdness
Speedtouch 546 FW 6.1.4.7
Many thanks
jim:quote
gprit
Re: DNS weirdness
All I know is that it is a Belkin router.....!
Oldjim
Resting Legend
Fixes: 63
Re: DNS weirdness
Follow the link which tells you how to do it on the Belkin https://www.opendns.com/start/device/belkin
