Re: DNS weirdness
gprit
Re: DNS weirdness
I joined this comminity specifically because I cannot access an ecommerce site that I am develping for a client.
www.dimplesdaisysanddandelions.co.uk/index/php
www.dimplesdaisysanddandelions.co.uk/admin
The client can see these....the third party hosting company can see these....I can see these from my local library.
but I can't see these going through Plusnet.  I dont have problems with any other sites.
I did a Tracert and this is what I get (aplies to all the above)
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Graham Pritchard>tracert www.dimplesdaisysanddandelions.co.uk/index.php
Unable to resolve target system name www.dimplesdaisysanddandelions.co.uk/index.
php.
Like someone else commented am thinking of moving from PlusNet becaus of this and the lack of interest from Support  - I need to work on this site - it is commercial and is losing money because I cnat complete development of the site.
Fixes: 12
Re: DNS weirdness
Well I've just tried and got through to all the locations you posted?  Had to correct this  www.dimplesdaisysanddandelions.co.uk/index/php ; to www.dimplesdaisysanddandelions.co.uk/index.php to make it work!
The admin page took me to a very bland login page, the .co.uk address took me to a puce "Page under construction"
nslookup resolved to 74.52.180.187
AH! Problems.  Tried again and using the same DNS server 212.159.6.10  it's now failing to resolve.  Seems a bit hit'n'miss
Maurice
gprit
Re: DNS weirdness
Thanks ...mistype re the / and .  (!)
It seems this thread has now been split as possibly it is different.
I have to say that I have intermittently been able to access for short periods....same as you.
Graham
Fixes: 62
Re: DNS weirdness
Running a few checks I can get to here OK
but the first link also works but only after I corrected the syntax to
http://www.dimplesdaisysanddandelions.co.uk/index.php
However a tracert only works to the site not to the index.php which I believe is normal
Tracing route to dimplesdaisysanddandelions.co.uk [74.52.180.187]
over a maximum of 30 hops:
Note - I am using OpenDNS
  1     1 ms    <1 ms    <1 ms  192.168.0.1
  2    41 ms    39 ms    42 ms  lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
  3   143 ms   235 ms   234 ms  gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
  4    38 ms    38 ms    39 ms  xe-1-2-0-0.lon20.ip.tiscali.net [213.200.79.233]
  5    38 ms    38 ms    38 ms  xe-6-3-0.lon10.ip4.tinet.net [89.149.187.101]
  6    38 ms    39 ms    39 ms  213.200.77.234
  7   148 ms   147 ms   148 ms  The-Planet.TenGigabitEthernet2-3.ar2.HOU1.gblx.n
et [64.214.196.58]
  8   238 ms   240 ms   238 ms  et5-4.ibr03.dllstx3.theplanet.com [70.87.253.49]
  9   152 ms   151 ms   152 ms  te9-1.dsr02.dllstx3.theplanet.com [70.87.253.22]
10     *        *        *     Request timed out.
11   156 ms   159 ms   160 ms  po2.car03.dllstx6.theplanet.com [70.87.254.158]
12   151 ms   151 ms   152 ms  bb.b4.344a.static.theplanet.com [74.52.180.187]
Note - I am using the OpenDNS servers
Fixes: 12
Re: DNS weirdness
Odd!  My reply to this thread came up in the DNS weirdness threadHuh  Perhaps one of the mods can move it here for consistencyHuh?
It now seems consistent that I can access the site - at least for the past 20 minutes or so.
Maurice
Fixes: 62
Re: DNS weirdness
Merged - you obviously posted while I was in the process of splitting the thread
gprit
Re: DNS weirdness
One minute ago I can also access all variations on the site........
I have previuosly run the Tracert and also received the trace results you had.
However I can almost guarantee that in the coming hours I will again NOT be able to access the sites.....
Two points:
1) what does my original messager mean? Where does the problem lie?
2 How can I trace where Planet.com is......and find out why it gets timed out?
thanks
Fixes: 62
Re: DNS weirdness
Reading Maurice's reply - I suggest you try switching the DNS servers in your router to the OPenDNS ones
208.67.222.222 and 208.67.220.220
Also you could try running a tracert to 74.52.180.187 and see if there is any difference
C:\Users\James>tracert 74.52.180.187
Tracing route to bb.b4.344a.static.theplanet.com [74.52.180.187]
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    39 ms    38 ms    38 ms  lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
  3    39 ms    39 ms    39 ms  gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
  4    38 ms    38 ms    38 ms  xe-1-2-0-0.lon20.ip.tiscali.net [213.200.79.233]
  6    39 ms    38 ms    38 ms  213.200.77.234
  7  148 ms  147 ms  148 ms  The-Planet.TenGigabitEthernet2-3.ar2.HOU1.gblx.net [64.214.196.58]
  8  238 ms  238 ms  239 ms  et5-4.ibr03.dllstx3.theplanet.com [70.87.253.49]
  9  152 ms  152 ms  153 ms  te9-1.dsr02.dllstx3.theplanet.com [70.87.253.22]
11  147 ms  164 ms  166 ms  po2.car03.dllstx6.theplanet.com [70.87.254.158]
12  146 ms  152 ms  152 ms  bb.b4.344a.static.theplanet.com [74.52.180.187]
Trace complete.
C:\Users\James>tracert www.dimplesdaisysanddandelions.co.uk
  2    57 ms    39 ms    38 ms  lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
  3    39 ms    38 ms    38 ms  gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
  4    68 ms    37 ms    39 ms  xe-1-2-0-0.lon20.ip.tiscali.net [213.200.79.233]
  5    40 ms    38 ms    39 ms  xe-6-3-0.lon10.ip4.tinet.net [89.149.187.101]
  6    38 ms    38 ms    38 ms  213.200.77.234
  7  147 ms  148 ms  147 ms  The-Planet.TenGigabitEthernet2-3.ar2.HOU1.gblx.net [64.214.196.58]
  8  237 ms  240 ms  239 ms  et5-4.ibr03.dllstx3.theplanet.com [70.87.253.49]
  9  151 ms  152 ms  153 ms  te9-1.dsr02.dllstx3.theplanet.com [70.87.253.22]
11  148 ms  147 ms  157 ms  po2.car03.dllstx6.theplanet.com [70.87.254.158]
12  154 ms  146 ms  152 ms  bb.b4.344a.static.theplanet.com [74.52.180.187]
Trace complete.
gprit
Re: DNS weirdness
since my reply two minutes ago I cant get in again!!!
gprit
Re: DNS weirdness
Quote from: Oldjim
How do I do that? I have no idea!!!!
jim:green quote fixed mod:end
Fixes: 62
Re: DNS weirdness
Worth trying this
C:\Users\James>tracert bb.b4.344a.static.theplanet.com
  2    39 ms    40 ms    38 ms  lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
  3    56 ms   221 ms   123 ms  gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
  4    40 ms    38 ms    45 ms  xe-1-2-0-0.lon20.ip.tiscali.net [213.200.79.233]
  5    38 ms    39 ms    38 ms  xe-6-3-0.lon10.ip4.tinet.net [89.149.187.101]
  7   147 ms   149 ms   147 ms  The-Planet.TenGigabitEthernet2-3.ar2.HOU1.gblx.nt [64.214.196.58]
  8   239 ms   238 ms   240 ms  et5-4.ibr03.dllstx3.theplanet.com [70.87.253.49]
  9   152 ms   153 ms   152 ms  te9-1.dsr02.dllstx3.theplanet.com [70.87.253.22]
11   148 ms   148 ms   147 ms  po2.car03.dllstx6.theplanet.com [70.87.254.158]
12   147 ms   147 ms   148 ms  bb.b4.344a.static.theplanet.com [74.52.180.187]
Trace complete.
The bit which puzzles me is that your site shares an IP address with a Planet fixed IP and isn't obviously separately identified - I have no idea what the implications of that are
Fixes: 62
Re: DNS weirdness
Re changing DNS - which router do you have.
However  when you can't get in can you try a tracert to the IP address as I think this bypasses the DNS servers
gprit
Re: DNS weirdness
I am getting a bit lost here.....! I dont usually delve into these things!
gprit
Re: DNS weirdness
I have a  Belkin router. How do I determione the IP address rather than the DNS?
tx
bluemonday
Re: DNS weirdness
The same problem is happenning for me again now - some websites are appearing down
