Re: Connection Dropping - session graph?
edwarne2001
My connection has been dropping overnight recently (first noticed last Thursday night, I think) and my speed, which was 6.5 Mbps until recently, is now 1 Mbps (and far less overnight). Is this BT trying to push me onto a more expensive service, like they did with my girlfriend?).
Fixes: 162
Your speed has dropped due to the large amount of disconnections on your line. If you pick up the phone is there any noise?
Have you tried any troubleshooting? http://www.plus.net/support/broadband/bbfaults/
 Chris Parr
 Plusnet Staff
edwarne2001
Assuming that was my graph, no I've got no noise on the line at the moment.
Fixes: 100
Mod Note
Posts split to new thread to aid a resolution.
Customer and Forum Moderator.
MelRocks
Hi there @edwarne2001,
If you have no noise then you need to raise a dropping connection fault. This can be done here:
http://faults.plus.net
Thank you.
edwarne2001
Thanks for the reply. I shall start by trying different cables and splitters in my premises before going further.
