Re: Connection Dropping - session graph?
- Re: Connection Dropping - session graph?
15-12-2015 11:28 AM
My connection has been dropping overnight recently (first noticed last Thursday night, I think) and my speed, which was 6.5 Mbps until recently, is now 1 Mbps (and far less overnight). Is this BT trying to push me onto a more expensive service, like they did with my girlfriend?).
Message 1 of 6
(825 Views)
5 REPLIES 5
15-12-2015 12:04 PM
Your speed has dropped due to the large amount of disconnections on your line. If you pick up the phone is there any noise?
Have you tried any troubleshooting? http://www.plus.net/support/broadband/bbfaults/
Message 2 of 6
(604 Views)
15-12-2015 1:47 PM
Assuming that was my graph, no I've got no noise on the line at the moment.
Message 3 of 6
(604 Views)
15-12-2015 1:57 PM
Mod Note
Posts split to new thread to aid a resolution.
Message 4 of 6
(604 Views)
15-12-2015 2:25 PM
Hi there @edwarne2001,
If you have no noise then you need to raise a dropping connection fault. This can be done here:
http://faults.plus.net
Thank you.
Thank you.
Message 5 of 6
(604 Views)
15-12-2015 4:12 PM
Thanks for the reply. I shall start by trying different cables and splitters in my premises before going further.
Message 6 of 6
(604 Views)
