Rapidgator.net
mathewwhite
Rapidgator.net
Morning.
Is there a block from PlusNet to Rapidgator.net?
I cannot access the website at all through PlusNet but I can through other ISPs?
thanks
Matt
Fixes: 6
Re: Rapidgator.net
Ok here:
Have you tried a different gateway?
Fixes: 96
Re: Rapidgator.net
Hi Matt,
What does a traceroute show?
I can access the site from my connection and this is what I see:
C:\Windows\System32>tracert rapidgator.net
Tracing route to rapidgator.net [195.211.221.116]
over a maximum of 30 hops:
  1    7 ms    3 ms    3 ms  home.gateway [192.168.1.254]
  2    16 ms    13 ms    14 ms  lo0.10.central10.pcl-bng02.plus.net [195.166.130.151]
  3    96 ms    36 ms    13 ms  irb.10.PCL-CR02.plus.net [84.93.249.82]
  4    15 ms    14 ms    14 ms  195.99.126.98
  5    15 ms    17 ms    14 ms  core4-te0-19-0-27.faraday.ukcore.bt.net [109.159.255.203]
  6    15 ms    14 ms    14 ms  peer2-et-9-3-0.faraday.ukcore.bt.net [62.6.201.167]
  7    14 ms    14 ms    15 ms  213.137.183.32
  8    15 ms    14 ms    14 ms  ldn-b3-link.telia.net [213.248.67.97]
  9    15 ms    15 ms    14 ms  ldn-bb1-link.telia.net [62.115.134.130]
10    32 ms    30 ms    29 ms  hbg-bb1-link.telia.net [80.91.245.4]
11    48 ms    47 ms    45 ms  s-bb3-link.telia.net [62.115.136.185]
12    54 ms    58 ms    54 ms  sap-b3-link.telia.net [80.91.249.78]
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *    ^C
I've a sneaking suspicion your routing is going to be going over BT's transit links.
This is interesting. It reports timeouts for both BT and Plusnet.
Fixes: 260
Re: Rapidgator.net
ok with PN and 1 VPN, failing on another VPN.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
mathewwhite
Re: Rapidgator.net
Im really sorry guys, I am not technical enough to understand any of what you have just suggested.
Embarrassed
mathewwhite
Re: Rapidgator.net
unbelievably - and perhaps co-incidentally - I have just tried rapidgator.net again and its working?
weird!
Fixes: 96
Re: Rapidgator.net
Glad to hear it's working again. For future reference this is how you execute a traceroute.
