Range extender or powerline adaptor
monk01
Hi
Can anyone explain to me which is better - a range extender or a powerline adaptor please? (please bear in mind I have little technical knowledge!)
Basically I have a wi-fi router but can only get wi-fi at one end of the house.
Also I will be looking to upgrade to fibre-optic broadband in a few months time. I assume I will get a new router when I upgrade - will I still need a range extender/powerline then?
Fixes: 10
Re: Range extender or powerline adaptor
If the equipment being used is in a fixed place (e.g. a desktop PC) powerline adapters are going to be better.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 26
Even if the other equipment is not in a fixed place, power line adapters with a wifi AP (e.g. Devolo) would be better than a range extender, as the latter needs to use the wifi band width to connect to the base router, which in effect halves the bandwidth.
monk01
Great, thank you for the quick replies
