Range Extender on old Thomson router
- Range Extender on old Thomson router
08-02-2014 5:36 PM
Am I correct in thinking that my new range extender (set up via WPS) cannot be used with my old Thomson router? Does it have WPS capability?
If not, will I need a new one & does that? Thank you.
Message 1 of 5
(1,103 Views)
4 REPLIES 4
Re: Range Extender on old Thomson router
08-02-2014 5:38 PM
WPS is only a way of simplifying setup - Can you configure the range extender manually?
What make and model is it?
Message 2 of 5
(529 Views)
08-02-2014 6:40 PM
It's a Trendnet TEW-736RE and although new to me has been used for a few months on a BT Homehub 3 with Plusnet and was set up (yes, very simply) via WPS.
I guess what I am asking is whether I can set it up even if the router doesn't have a WPS button.
Message 3 of 5
(529 Views)
08-02-2014 6:48 PM
You can - Follow the 'Setup Wizard Configuration' section on page 7 of the manual.
HTH
HTH
Message 4 of 5
(529 Views)
09-02-2014 12:16 AM
Thank you. It works!!
Message 5 of 5
(529 Views)
