Randon daily disconnections
- Randon daily disconnections
- « Previous
- Next »
Re: Randon daily disconnections
29-06-2012 8:51 AM
Yes you do, as the test socket is a normal BT style socket and your normal modem/router cable is not compatible.
Message 31 of 38
(433 Views)
29-06-2012 9:04 AM
Thanks - thought so, but always like to be sure.
Message 32 of 38
(433 Views)
29-06-2012 12:20 PM
Quote from: _Adam_Walker_ That's fine, I'll look out for another reply from you.
Adam - sorry I'm going to a bit late with this, the morning didn't quite go as planned, but I will be connected to the test socket from 2.30pm.
Can you carry out the tests as soon as possible after that please, as I will have to return the setup to normal - due to the position of my min phone socket and power points, leaving things set up that way for an extended time is not practical.
Message 33 of 38
(433 Views)
29-06-2012 12:51 PM
Message 34 of 38
(433 Views)
29-06-2012 2:34 PM
All yours Adam
Message 35 of 38
(433 Views)
29-06-2012 2:41 PM
I've just performed the test, whilst this was completely worth doing the results didn't look any different I'm afraid.
I have added the results of the test to your account as they'll be useful to us if you decide to raise a fault.
Message 36 of 38
(433 Views)
29-06-2012 2:52 PM
OK thanks I
As the disconnections don't usually cause me a problem, and speed is reasonable, I think I'll just carry on for now -another 46 days and I'm away for 3 weeks, so I'll 'suck it & see'
Message 37 of 38
(433 Views)
29-06-2012 4:16 PM
Message 38 of 38
(433 Views)
- « Previous
- Next »
