Random missing e-mails
- Re: Random missing e-mails
25-08-2007 11:24 PM
I wonder if anybody is having the same problem.
In the last half hour I have sent 4 test e mails to the same (Net+) address, 2 have arrived the other two have not.
Support have suggested that it is my anti virus, this is obviously nonsense, because half have been sent.
It is not Outlook either because the recipient is checking the Squirrel mail.
The reason for doing sending these test is because over the last two days, the recipient has complained of missing e-mails.
Any constructive suggestions will be very welcome.
25-08-2007 11:28 PM
There have been reports of delayed email recently so see if they arrive in the morning.
Note: Just because they were sent within a small time frame does not mean they will all take the same route and thus arrive within the same time frame.
25-08-2007 11:31 PM
26-08-2007 9:42 PM
I believe plusnet's spam detector is just not right. I found loads of genuine emails in my spam folder recently. I didn't even realise plusnet was filtering my mail. Yes, some of those emails were important and work related. Not happy. I have set all spam detected emails to be delivered to me regardless and I sort them out myself. Frankly, this makes PN's spam filters pointless to me.
I bet ya your missing mails are sitting in that spam folder!
26-08-2007 10:44 PM
This morning I sent 10 test emails to another plusnet a/c, only 4 or 5 have arrived up to now.
28-08-2007 11:07 AM
today out of 5 e mails only one got to the recipient.
I reported the fault 2 days ago ( ID: 22691000 ) but without any neaningful responses.
Does anybody know, if deleting the mailbox and creating it again, will help?
I am really getting frustrated about this.
28-08-2007 11:36 AM
I don't think deleting and recreating the mailbox is going to help to be honest. I've passed your ticket to our NEt Ops guys to see if they're able to check our relay logs based on the information you've provided.
Am I correct in assuming that you're using relay.plus.net to send your messages?
28-08-2007 12:23 PM
Yes, I am using relay.plus.net
28-08-2007 1:57 PM
I raised a ticket only to be told it was my friends ISP. I said that I could not even send it to myself and after sending myself about 20 emails, with different parts of the message, I found if it contained
‘This is the worst virus announced by CNN, it has been classified by’
it would not be delivered.
So I told them this and they then implied it was spam. It was not in my spam folder.
I told them it was not in the spam folder and got this reply:
“We do not normally drop email but in the instance of a particularly pervasive virus email which did contain a string of text simular if not identicle to that you are quoting we took the decision to drop any emails matching exact content or subject lines on the feedback and request of customers.
This email was flooding our mail platform and having a servere impact on our customers' experience.
You will simply need to use a different sentence structure.”
This is not satisfactory as I don’t know what part of the message to tell my friends to re-structure, unless I spend a lot of time breaking down the message and finding out which part needs changing.
I had a similar problem in 2006, but this was bounced because of the subject line.
I think it would be only common courtesy for PlusNet to inform its members, by email, of what they are blocking.
28-08-2007 2:29 PM
Never received 2 emails that were sent to me last Friday. Today sent 4 emails - 3 turned up - no 1 first, no 4 second, no 3 third and no sign of the second one at all.
No 1 was on mxcore 10, no. 4 on mxcore 10, 3 on mxcore 15 - can't say which mxcore no 2 was on.
There is clearly something up (again).
28-08-2007 2:40 PM
Quote from: running This is not satisfactory as I don’t know what part of the message to tell my friends to re-structure, unless I spend a lot of time breaking down the message and finding out which part needs changing.
When we've done this kind of blocking in the past it's been based on the entire subject line with the exception of the words "Megadik" and "Wundercum" which were wildcarded. The blocking would have been done because the subject exactly matches that of a particular virus. Changing the wording slightly would mean that it isn't blocked.
Plusnet Technology
28-08-2007 2:49 PM
Quote from: wuggywugrat
Have you checked the spam folder in case they've been picked up as spam?
Plusnet Technology
28-08-2007 3:19 PM
Still no sign of email no.2 sent an hour ago exactly...
28-08-2007 5:17 PM
- Sender's address
- Recipient's address
- Time sent
- Error messages/Failed delivery notifications where appropriate
It would also help if you cc'd your test messages to a non-PlusNet account to make sure they turn up there.
28-08-2007 6:57 PM
At 10:49 this morning. The subject message was "28.8.07 1 of 5", "28.8.07 2 of 5", etc..
Only 3 and 5 arrived . Nothing in the Spam folder.
