Random disconnects.
- Random disconnects.
Random disconnects.
10-02-2012 4:51 PM
I have a ticket open (50504139) and am starting to feel like I'm going around in circles. The help I've been getting has been generally pretty good but it's not exactly going anywhere.
I'll randomly disconnect (from the exchange, I log in to the router and it tells me to check the router is plugged into the phone line), there is nothing happening at the time that I can see that would cause the disconnections. If you look at the picture:
Hopefully it'll work, it shows it disconnecting at 2/3/4am when everyone is in bed. I had an engineer out today who couldn't find a fault and the ticket seems to suggest that it's my fault for using the IPV6 trial log in, a misconfigured router, except I use two different routers (both IPV6 capable) and the disconnections occur even if I'm using my normal log in details, I'm going to be pretty unhappy if I get hit with a £60 call out fee because PN are blaming it on a misconfigured router!
The fault though is odd, I'll have uptime of a day and a bit and then it'll drop, and drop a few more times, eventually becoming stable for a while before starting to drop again. I'm plugged into the master socket, I've changed filters, I've changed the modem cable and of course tried different routers. So, is there anything else I can do on my end to try and figure out what the problem is?
Message 1 of 5
(6,922 Views)
4 REPLIES 4
Re: Random disconnects.
10-02-2012 5:22 PM
HI David W,
As long as you're in the test/master socket and you tried alternative filters/routers there's nothing else you can do and you definitelycould wouldn't be subject to a charge.
Jojo
Jojo
Message 2 of 5
(360 Views)
10-02-2012 6:01 PM
Could be subject to a charge? Hoping that's a typo Jojo
/edit - it's also not an IPV6 issue, the disconnects happen on my normal (IPV4) account so the different accounts doesn't seem to have any effect on the matter.
Message 3 of 5
(360 Views)
11-02-2012 11:17 AM
Is there anyone who doesn't get random disconnects? I thought it was just part of the service.
Message 4 of 5
(360 Views)
13-02-2012 10:19 AM
Hi David W,
Yes, sorry about the typo! Amended that now.
Jojo
Jojo
Message 5 of 5
(360 Views)
