Random disconnects
- Re: Random disconnects
Random disconnects
23-03-2012 11:55 AM
Morning
Why is it that once you get one problem, you always seem to get 2 or 3 more?
I recently had my d/l SNR sorted - thanks Jojo - but now I seem to be suffering from random disconnects. I don' always spot them because I'm not always on the PC but I had a look at my router log after suffering one this morning, and noticed there have been quite a few.
Get the connection back, usually almost instantly, but it is still a PITA.
Any chance someone can have a look? - please.
Message 1 of 6
(915 Views)
5 REPLIES 5
23-03-2012 1:14 PM
I'm not seeing many drops to be honest. Are you seeing more than that?
Message 2 of 6
(355 Views)
23-03-2012 3:11 PM
Jojo - can't interpret those logs, but extracted the following from router logs:
Disconnected Reconnected
08.55.22 08.57.16 18/03/12
14.34.06 14.35.17 18/03/12
10.04.30 10.06.13 19/03/12
21.49.13 21.50.21 19/03/12
19.13.38 19.15.13 20/03/12
19.41.15 19.42.23 21/03/12
19.24.12 19.24.48 21/03/12
07.10.02 07.11.07 22/03/12
09.50.54 09.53.31 23/03/12
Message 3 of 6
(355 Views)
23-03-2012 4:10 PM
Hi jab1,
Hi, yes, they match with the graph virtually. You currently have interleaving off, so if you raise an intermittent fault then interleaving will be applied. If you want to keep interleaving off, then you'd have to suffer the odd drop.
Jojo
Jojo
Message 4 of 6
(355 Views)
23-03-2012 4:32 PM
OK thanks Jojo
For now, I'll keep interleaving off - so long as the drops don't get anymore frequent or last for any longer. But if they do -in the words of 'The Terminator' - I'll be back
Message 5 of 6
(355 Views)
23-03-2012 5:00 PM
Sure, no problem, just let us know if they get too much
Message 6 of 6
(355 Views)
