Raise Upload Speed
philstoke
Raise Upload Speed
Hi. As I have an online web store and it is taking ages to upload items can my upload speed be raised, would it affect downloads  and would I have to change any setting in my router
Fixes: 154
Re: Raise Upload Speed
welcome to the forum Smiley
are you on adsl1 or 2 do you know? that will help in determining your options.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
Correction: Are you on 20CN ADSL Max  or 21CN WBC ADSL is the correct question to ask (you can be on ADSL1 over 21CN and still have uncapped upload).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
philstoke
Your getting too technical now, lol
I'm positive its ADSL2, I just tried to login to my router to check but cannot remember the login details, I have them written down somewhere
I am getting approx 10500 kbps download and 376 kbps upload at the moment
Fixes: 10
That's OK then. If the download is faster than 8Mbps you are on 21CN and uncapping the upload is free (on 20CN it costs extra).
Fixes: 10
Quote from: philstoke
If it's a Plusnet supplied router look on it's bottom!
Plusnet Staff
Plusnet Staff
Fixes: 5
I've placed an order for your upload speeds to be uncapped - this should take effect as over the early hours on Tuesday morning.
Chris Pettitt
Cloud Environments Engineer
philstoke
Thats Great Thanks Very Much, I take it I don't have to do anything my end
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 5
You don't need to do anything at your end.
Chris Pettitt
