Radius Log Request
- Radius Log Request
Re: Radius Log Request
25-07-2015 8:45 AM
25-07-2015 12:42 PM
26-07-2015 9:38 AM
26-07-2015 10:14 AM
something switched on for that period?
Again nothing for 14.25 on 25 july - almost identical graph to 20.45pm on 22July.
Maybe just try to leave it without a manual resync to see when/if the Rx drops back on its own.
26-07-2015 11:48 AM
Nothing switched on here during that period - I was laid in bed shivering/sweating.
I will leave it alone -going back to bed.
26-07-2015 5:24 PM
Looks like you had a loss of sync at about 1425/6 ish on the 25th (sync speed graph to match such incidents is always useful), probably the line going intermittent and the resync occurring whilst it was still bad (at slow speed) then the noise reducing so the SNRM then rises. Can you turn the Average SNRM plotting back on again as well, that's sometimes handy.
A "graceful disconnect & resync" might be the best thing (as mentioned in reply #70) when the noise is absent.
27-07-2015 11:27 AM
Router log:
DSL Connection
Link Information
Uptime: 1 day, 20:48:33
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 780 / 7,948
Data Transferred (Sent/Received) [MB/GB]: 120.25 / 0.97
Output Power (Up/Down) [dBm]: 11.8 / 20.2
Line Attenuation (Up/Down) [dB]: 16.7 / 33.5
SN Margin (Up/Down) [dB]: 6.2 / 12.4
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 852 / 1
FEC Errors (Up/Down): 15,229 / 23,471
CRC Errors (Up/Down): 24 / 96
HEC Errors (Up/Down): 73 / 3,779
BT speedtest::
1. Best Effort Test: -provides background information.
Download Speed
6.85 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.85 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.01 Mbps
Upload Speed
0.52 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.52Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
RSL plots to follow.
27-07-2015 11:36 AM
27-07-2015 11:39 AM
27-07-2015 11:46 AM
I really think it would be good to do a CLT asap, see if they can catch the line problem - what do you think?
27-07-2015 12:19 PM
No fault was found after automated testing.
27-07-2015 12:23 PM
Hopoefully your sync speed will have returned to near normal John, as the CLT is an intrusive test as you know, and gives a break in sync of just under 3 minutes (usually).
28-07-2015 9:47 AM
I will have post the speed logs from the laptop - hadn't noticed that somehow they had been deactivated on the desktop.
28-07-2015 10:20 AM
28-07-2015 11:20 AM
