RUOTER
jaworskiemil11
RUOTER
Witam jak zmienic haslo dostepu do routora wi fi , ktos mi sie podlaczyl i ciagnie dane przez router.?
Fixes: 50
Re: RUOTER
Google translation: Hello, how to change the password for the wifi router, someone connected to me and pulls data through the router.
Customer and Forum Moderator.
Seasoned Pro
Fixes: 5
Re: RUOTER
Thanks @Strat - I forget Google could do it.Smiley
Fixes: 127
Re: RUOTER
Moderators Note.
OP seems to be a PN customer
Will Moderate For Thanks
Seasoned Pro
Fixes: 5
Re: RUOTER
@dvorak Thanks - use of Polish just made me suspicious.
Fixes: 9
Re: RUOTER
Jakiego routera masz?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Jonpe
Seasoned Pro
Re: RUOTER
Be careful with Google Translate; the owner of a lottery site used it to translate something from the French Euromillions site, and somehow a reference to the French draw was translated into English as, "The pulling of the French woman".  Any tips gratefully received, I'm sure.Smiley
Fixes: 254
Re: RUOTER
Welcome to the community forums @jaworskiemil11
Here's a step by step guide to changing your wireless password.
1. Go-to your router settings at http://192.168.1.254
2. Press the enter button
3. Click on Advanced Settings
4. Enter the admin password, which is the admin password on the back of the router
5. Click on Continue to Advanced Settings
6. Click on Wireless
7. From here you can change the password you use to connect your wireless devices
8. Click on Apply
I hope this helps. -Anoush
