[REQUEST] Change IP Address
- [REQUEST] Change IP Address
18-06-2011 3:27 PM
My IP address was recently released by a team of hackers, they've constantly been taking over my Hotmail account because of this.
I want to make a new one but I know that It will just get hacked again.
I am also recieving many disconnections and DDoS attempts which i've blocked with the program bullguard.
Please help?
Re: [REQUEST] Change IP Address
18-06-2011 3:30 PM
18-06-2011 3:34 PM
But im not too sure.
18-06-2011 3:42 PM
Out of interest - since it is out of my expertise - why would knowing your IP address allow hackers to get into your Hotmail account
A check on your posting history shows that it was always from the same IP address so yes it is fixed
18-06-2011 3:45 PM
And yeah there is a user form for Hotmail users which is often taken advtange of.
All the hacker needs is my IP to be able to revert the account.
Thanks for your help, when do you think the member center will be back online?
18-06-2011 3:54 PM
Didn't realise there was such a form, may explain the recent increase in hotmail accounts being compromised and used to send out spam.
18-06-2011 4:04 PM
Does this stop if you set your Plusnet Broadband Firewall - https://portal.plus.net/my.html?action=firewall - to "High" ?
That should stop any attacks getting to your router
If Hotmail really is that vulnerable, then you should look elsewhere for an email account, as changing your IP address is unlikely to be a long term solution.
18-06-2011 4:29 PM
18-06-2011 4:43 PM
As far as I know you can't request a change only to move from fixed to dynamic.
Do you have an icon as shown here https://portal.plus.net/my.html?action=myconnection
However if you change how do Hotmail see the change and work with it.
18-06-2011 4:49 PM
Hotmail is a total disaster
19-06-2011 12:00 PM
Quote from: Exsert I'm pretty sure my IP is static?
Note your IP address. Restart your router. If your IP address remains the same then it's fixed.
19-06-2011 5:00 PM
Note that it isn't necessary to restart the router just to disconnect and reconnect from Plusnet also a quick disconnect/reconnect may not give a new IP address
19-06-2011 7:32 PM
19-06-2011 7:38 PM
19-06-2011 7:53 PM
