REIN back with a vengeance? #100344275
MsDizzie
Well its been almost 6 months with untroubled service... then wham, multiple disconnects from Monday 2 Mar.
3 Mar from 11:42 onwards it was up and down consistently, so unusable until 17:05
I've contacted Plusnet and ticket #100344275 was created for me (72 hours for testing).
The wiring was checked and an ADSL Mk2 faceplate fitted 18 Sep 2014, no other changes have been made.
Current stats:
xdsl info expand=enabled
Physical Layer Statistics:
  Modem state:                  up
  Up time (Days hh:mm:ss):      0 days, 21:14:23
  xDSL Standard:                ITU-T G.992.5
  xDSL Annex:                  Annex A
  Channel Mode:                      Interleaved
  Number of reset:              12
  Chipset Vendor info (G.994.1):  Local Remote
    Country code:                  B500  B500
    Specific:                      0000  71C8
  System Vendor info (showtime): Local Remote
    Country code:                0F00  0000
    Specific:                    3C61  0000
  Bearers generic info          DS        US
    Payload rate [Kbps]: 14202    888
    Attenuation [dB]:    28.0          13.9
    Margins [dB]:        8.6            16.2
    Output power [dBm]:  0.0            12.4
    Number of bearers:          1
    Bearer 0                    DS        US
      INP [DMT symbols]:    1.07          2.00
      Delay [ms]:          7.98          8.00
      Depth []:          64            0.00
      R:                  16        0
G.997.1 Statistics (Current):
  Failures:
    Line failures              Near end
      Loss of signal (LOS):  1
      Loss of frame (LOF):    8
      Loss of power (LPR):  0
  Performance monitoring:
    Line PM:          Near end
      Error second (ES):    1949
    Channel PM:        Near end Far end
      Bearer 0:
        Code Violation (CV):    2340    0
        FEC:                    20817635 300
    ATM data path PM:            Near end Far end
      Bearer 0:
        HEC violation count (HEC):      1921    N/A
G.997.1 Statistics (last 15 minutes):
  Failures:
      Loss of signal (LOS):  0
      Loss of frame (LOF):    0
    Line PM:          Near end
      Bearer 0:
        FEC:                    20817635 300
      Bearer 0:
G.997.1 Statistics (last 24 hours):
  Failures:
    Line PM:          Near end
      Error second (ES):    246
      Bearer 0:
        FEC:                    20817635 300
      Bearer 0:
but what I am really worried about is the attached graph
Fixes: 5
Re: REIN back with a vengeance? #100344275
Our faults team have been given the information, but they have been given literally, no information. I'm addressing that, but I'd be really grateful if you'd update ticket 100344275 (portal.plus.net) with details of the symptoms.
 Tony T
Fixes: 26
Hi MsDizzie,
That looks grim, it rather looks like something local being switched on, warming up (downward shift) and spewing out REIN, then suddenly switching off (sharp upward shift), ceasing to emit REIN.
As much for Tony as anything else, what happened back here - http://community.plus.net/forum/index.php/topic,131451.msg1154963.html#msg1154963 - was a SNRM reset performed at that time?  Were those issues fully resolved?
Kevin
MsDizzie
Townman: yes an SRNM reset was done, and I've been happily running at around 16Mb at 3db
I was told that some line tests would be done over the next 72 hrs (from Tues) so I guess that hasn't been happening, and how could I give more information at the time when I didn't have any access?!?!?
Anyway, I've updated the ticket and pointed the team to the forum.
MsDizzie
Well its still not reliable, and the order to fix the SNR to 6db obviously didn't take.
<38> Mar 11 11:15:23 PPP CHAP Chap receive success : authentication ok
Mar 12 04:23:03 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 210.38.2.86 Dst ip: 87.115.75.16 Type: Destination Unreachable Code: Port Unreacheable
<132> Mar 12 15:25:27 PPP link down (Internet) [87.115.75.16]
<39> Mar 12 15:38:12 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 12 15:38:12 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 12 15:38:13 PPP CHAP Chap receive success : authentication ok
<132> Mar 12 15:38:16 PPP link up (Internet) [146.199.107.94]
<85> Mar 12 15:38:16 FIREWALL event (1 of 1): deleted rules
<14> Mar 12 15:38:25 CONFIGURATION saved by TR69
<132> Mar 13 14:02:54 PPP link down (Internet) [146.199.107.94]
<85> Mar 13 14:02:55 FIREWALL event (1 of 1): created rules
<85> Mar 13 14:02:55 FIREWALL event (1 of 1): modified rules
<39> Mar 13 14:03:08 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 13 14:03:08 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 13 14:03:10 PPP CHAP Chap receive success : authentication ok
<132> Mar 13 14:03:11 PPP link up (Internet) [212.159.50.214]
<173> Mar 16 11:13:12 xDSL linestate down
<85> Mar 16 11:13:13 FIREWALL event (1 of 1): created rules
<85> Mar 16 11:13:13 FIREWALL event (1 of 1): modified rules
<173> Mar 16 11:13:32 xDSL linestate down
<132> Mar 16 11:14:02 PPP link down (Internet) [212.159.50.214]
<173> Mar 16 11:14:03 xDSL linestate down
<173> Mar 16 11:14:24 xDSL linestate down
<173> Mar 16 11:14:46 xDSL linestate up (ITU-T G.992.5; downstream: 14650 kbit/s, upstream: 888 kbit/s; output Power Down: 20.6 dBm, Up: 12.8 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 6.3 dB, Up: 15.8 dB)
<39> Mar 16 11:14:59 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 11:14:59 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 11:15:02 PPP CHAP Chap receive success : authentication ok
<39> Mar 16 11:16:15 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 11:16:15 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 11:16:15 PPP CHAP Chap receive success : authentication ok
<39> Mar 16 11:17:28 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 11:17:29 PPP CHAP Receive challenge (rhost = PCL-AG02)
<38> Mar 16 11:17:29 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 11:17:29 PPP link up (Internet) [91.125.88.155]
<85> Mar 16 11:17:30 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 11:17:43 CONFIGURATION saved by TR69
<173> Mar 16 11:29:33 xDSL linestate down
<85> Mar 16 11:29:34 FIREWALL event (1 of 1): created rules
<85> Mar 16 11:29:34 FIREWALL event (1 of 1): modified rules
<173> Mar 16 11:29:50 xDSL linestate down
<132> Mar 16 11:30:19 PPP link down (Internet) [91.125.88.155]
<173> Mar 16 11:30:20 xDSL linestate down
<173> Mar 16 11:30:47 xDSL linestate down
<173> Mar 16 11:31:13 xDSL linestate up (ITU-T G.992.5; downstream: 20416 kbit/s, upstream: 888 kbit/s; output Power Down: 19.1 dBm, Up: 12.0 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.4 dB, Up: 16.9 dB)
<39> Mar 16 11:31:15 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 11:31:16 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 11:31:16 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 11:31:19 PPP link up (Internet) [146.199.152.223]
<85> Mar 16 11:31:20 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 11:31:28 CONFIGURATION saved by TR69
<37> Mar 16 11:35:41 LOGIN User admin logged in on [HTTP] (from 192.168.1.76)
<37> Mar 16 11:38:47 LOGOUT User admin logged out on TELNET (192.168.1.76)
<37> Mar 16 11:38:55 LOGIN User admin logged in on TELNET (192.168.1.76)
<173> Mar 16 12:47:19 xDSL linestate down
<85> Mar 16 12:47:19 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:47:19 FIREWALL event (1 of 1): modified rules
<173> Mar 16 12:47:40 xDSL linestate down
<173> Mar 16 12:48:10 xDSL linestate down
<132> Mar 16 12:48:16 PPP link down (Internet) [146.199.152.223]
<173> Mar 16 12:48:36 xDSL linestate down
<173> Mar 16 12:49:02 xDSL linestate up (ITU-T G.992.5; downstream: 17687 kbit/s, upstream: 888 kbit/s; output Power Down: 19.2 dBm, Up: 12.1 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.4 dB, Up: 17.3 dB)
<39> Mar 16 12:49:13 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 12:49:13 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 12:49:13 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 12:49:14 PPP link up (Internet) [80.189.237.165]
<85> Mar 16 12:49:14 FIREWALL event (1 of 1): deleted rules
<173> Mar 16 12:49:34 xDSL linestate down
<85> Mar 16 12:49:35 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:49:35 FIREWALL event (1 of 1): modified rules
<173> Mar 16 12:49:55 xDSL linestate down
<173> Mar 16 12:50:26 xDSL linestate down
<132> Mar 16 12:50:33 PPP link down (Internet) [80.189.237.165]
<173> Mar 16 12:50:52 xDSL linestate down
<173> Mar 16 12:51:18 xDSL linestate up (ITU-T G.992.5; downstream: 17234 kbit/s, upstream: 888 kbit/s; output Power Down: 19.2 dBm, Up: 12.1 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.3 dB, Up: 17.1 dB)
<39> Mar 16 12:51:29 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 12:51:30 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 12:51:30 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 12:51:30 PPP link up (Internet) [146.200.145.130]
<85> Mar 16 12:51:31 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 12:51:45 CONFIGURATION saved by TR69
<173> Mar 16 12:51:50 xDSL linestate down
<85> Mar 16 12:51:50 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:51:50 FIREWALL event (1 of 1): modified rules
<37> Mar 16 12:51:59 LOGOUT User admin logged out on TELNET (192.168.1.76)
<37> Mar 16 12:52:02 LOGIN User admin logged in on TELNET (192.168.1.76)
<173> Mar 16 12:52:11 xDSL linestate down
<173> Mar 16 12:52:37 xDSL linestate down
<132> Mar 16 12:52:40 PPP link down (Internet) [146.200.145.130]
<173> Mar 16 12:52:58 xDSL linestate down
<173> Mar 16 12:53:24 xDSL linestate down
<173> Mar 16 12:53:50 xDSL linestate up (ITU-T G.992.5; downstream: 13204 kbit/s, upstream: 888 kbit/s; output Power Down: 19.3 dBm, Up: 12.2 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.2 dB, Up: 17.3 dB)
<39> Mar 16 12:53:51 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 12:53:52 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 12:53:52 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 12:53:55 PPP link up (Internet) [87.113.203.138]
<85> Mar 16 12:53:56 FIREWALL event (1 of 1): deleted rules
<173> Mar 16 12:54:22 xDSL linestate down
<85> Mar 16 12:54:22 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:54:22 FIREWALL event (1 of 1): modified rules
<173> Mar 16 12:54:42 xDSL linestate down
<24> Mar 16 12:54:59 [CWMP] Connection timed out
<132> Mar 16 12:55:12 PPP link down (Internet) [87.113.203.138]
<173> Mar 16 12:55:12 xDSL linestate down
<173> Mar 16 12:55:38 xDSL linestate down
<173> Mar 16 12:56:04 xDSL linestate up (ITU-T G.992.5; downstream: 16924 kbit/s, upstream: 888 kbit/s; output Power Down: 19.2 dBm, Up: 12.1 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.4 dB, Up: 17.1 dB)
<39> Mar 16 12:56:08 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 12:56:09 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 12:56:09 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 12:56:09 PPP link up (Internet) [87.113.193.216]
<85> Mar 16 12:56:10 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 12:56:23 CONFIGURATION saved by TR69
<173> Mar 16 12:56:36 xDSL linestate down
<85> Mar 16 12:56:36 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:56:36 FIREWALL event (1 of 1): modified rules
<173> Mar 16 12:56:57 xDSL linestate down
<173> Mar 16 12:57:14 xDSL linestate down
<132> Mar 16 12:57:29 PPP link down (Internet) [87.113.193.216]
<173> Mar 16 12:57:44 xDSL linestate down
<173> Mar 16 12:58:10 xDSL linestate down
<173> Mar 16 12:58:36 xDSL linestate up (ITU-T G.992.5; downstream: 16660 kbit/s, upstream: 888 kbit/s; output Power Down: 19.2 dBm, Up: 11.9 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.4 dB, Up: 17.1 dB)
<39> Mar 16 12:58:40 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 12:58:40 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Mar 16 12:58:40 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 12:58:43 PPP link up (Internet) [80.189.38.145]
<85> Mar 16 12:58:44 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 12:58:52 CONFIGURATION saved by TR69
<173> Mar 16 12:59:08 xDSL linestate down
<85> Mar 16 12:59:08 FIREWALL event (1 of 1): created rules
<85> Mar 16 12:59:08 FIREWALL event (1 of 1): modified rules
<173> Mar 16 12:59:29 xDSL linestate down
<173> Mar 16 12:59:59 xDSL linestate down
<132> Mar 16 13:00:00 PPP link down (Internet) [80.189.38.145]
<173> Mar 16 13:00:25 xDSL linestate down
<173> Mar 16 13:00:51 xDSL linestate up (ITU-T G.992.5; downstream: 11333 kbit/s, upstream: 888 kbit/s; output Power Down: 19.2 dBm, Up: 11.7 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.1 dB, Up: 17.0 dB)
<173> Mar 16 13:01:23 xDSL linestate down
<173> Mar 16 13:01:44 xDSL linestate down
<173> Mar 16 13:02:14 xDSL linestate down
<173> Mar 16 13:02:40 xDSL linestate down
<173> Mar 16 13:03:06 xDSL linestate up (ITU-T G.992.5; downstream: 17466 kbit/s, upstream: 888 kbit/s; output Power Down: 19.1 dBm, Up: 12.0 dBm; line Attenuation Down: 27.5 dB, Up: 13.9 dB; snr Margin Down: 3.4 dB, Up: 17.2 dB)
<39> Mar 16 13:03:12 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 13:03:12 PPP CHAP Receive challenge (rhost = PCL-AG01)
<38> Mar 16 13:03:13 PPP CHAP Chap receive success : authentication ok
<132> Mar 16 13:03:13 PPP link up (Internet) [87.115.14.222]
<85> Mar 16 13:03:13 FIREWALL event (1 of 1): deleted rules
<14> Mar 16 13:03:27 CONFIGURATION saved by TR69
<81> Mar 16 13:13:50 FIREWALL icmp check (1 of 2): Protocol: ICMP  Src ip: 81.215.228.171 Dst ip: 87.115.14.222 Type: Destination Unreachable Code: Port Unreacheable
<84> Mar 16 13:17:42 IDS scan parser : tcp port scan: 212.56.73.91 scanned at least 10 ports at 87.115.14.222.  (1 of 1) : 212.56.73.91    87.115.14.222  0040 TCP 80->52232 [...R..] seq 3985718690 win 0
Fixes: 212
Yup it certainly doesn't look pretty today
Interestingly the target SNR has gone back down to 3db again.
The tickets back with our Faults team and they'll get that looked into as soon as possible.
 Matthew Wheeler
MsDizzie
Thanks for the Radius plot. There's not a real pattern to it looking at that  Cry
Fixes: 26
The RS plots are horrid.  What is the sample interval?  Can you set this to 10 seconds and 720 plot points.  This will make graphs cover 2 hours and might give clearer REIN profiling.
Do you have a portable MW radio?  If so try wandering around with it tuned to 612kHz and see if you can detect localised noise, particularly when you are experiencing the disconnections.
MsDizzie
Townman, all my plots are set to 10 seconds and 720 plot points  Wink
The last graph I supplied in Reply #4 doesn't really show a marked deterioration of signal prior to the subsequent re-connects.
Also, I don't have a portable radio, so the "REIN walkabout" is off.
Fixes: 26
Will need to see what the faults team propose.  In the meantime please keep RS running, it might just still spill the beans.
Do you have a car with a MW radio?  If yes it might be worth giving that a listen when / if you get another episode as shown in reply #4 graph.
MsDizzie
OK... can someone shed any light on the difference between these results please?
<173> Mar 16 18:08:43 xDSL linestate up (ITU-T G.992.5; downstream: 19163 kbit/s, upstream: 888 kbit/s; output Power Down: 19.8 dBm, Up: 12.2 dBm; line Attenuation Down: 28.0 dB, Up: 13.9 dB; snr Margin Down: 6.2 dB, Up: 17.0 dB)
<39> Mar 16 18:08:45 PPP CHAP Receive challenge (rhost = acc-aln1.ots)
<39> Mar 16 18:08:46 PPP CHAP Receive challenge (rhost = PTW-AG03)
And
(BT Wholesale Broadband Performance Test shows similar results 11.66 Mbps and 0.76 Mbps, latency 31ms)
Fixes: 26
It is likely that the profiles have yet to catch up.
When doing the BTw speed test, always do the further diagnostics - this will tell you the BT profile.
Then go look at the current speed in the PN portal (see the speed issues thread for details).
Unless these are aligned to your synch speed (88.2% thereof) you will not see the best data speed.
Fixes: 212
The profile on our end has increased however the connection hasn't dropped since.
If you log into your router and disconnect then reconnect you should see the increase.
 Matthew Wheeler
MsDizzie
Thank you Townman and Matthew.
And BT Performance Test: Download 16.05 (Profile 16.91) Upload 0.66 (Profile 0.83) so almost ties up  Wink
I'll pull together a selection of RS graphs later.
Fixes: 26
Quote from: Matthew
Matthew,
I thought this issue had been fixed?
Kevin
