REALLY slow speeds this morning
edwardw
Getting very slow web pages this morning, things on my phone wouldnt load so i had to switch over to 3G.
3G is much faster, are there any issues that we are aware of?
edwardw
Re: REALLY slow speeds this morning
Just done a BT speed test, see attachement..
Should be getting 60/10 on this line!
edwardw
Fixes: 62
I really don't think this will be a factor but what is the Current Line Speed from https://portal.plus.net/my.html?action=data_transfer_speed
Have you tried connected by wire as opposed to wireless
edwardw
Phone exchange:
ROTHWELL
Estimated line speed:
52Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-29 10:43:45
Current line speed:
53.2 Mb
Wired is a bit better but still no where as good as it should be !
dick:quote
xist
I didn't want to start a topic saying more or less the same thing, but today i've had the same thing happen....speeds are like walking in treacle. I've just had the first 30 seconds of a two and a half minute youtube video buffer 3 times on me. The BT Speedtester diagnostics aren't working at the moment for my line either.
PN profile is at 6MB, no lost connection or SNR blips, 20CN ADSL line, connected at Master socket. Was ok yesterday, is crippled today....
Fixes: 162
We're taking a look into this, at first glance there's nothing obvious causing these issues.
 Chris Parr
 Plusnet Staff
edwardw
Any update?
Im still crawling along here!
Download : 0.63mpbs
Upload : 9.35mpbs
Ping : 250
Seems like u/l is ok just a downstream problem.
dick:quote
xist
Diagnostic still won't work but here's a result...
Click the image to actually see this one...
Nothing has changed at my end regarding my connection so i'm clueless and a little frustrated at the moment...
Fixes: 162
I'd strongly suggest opening a fault ticket just in case we can't find anything wrong, you can do that at faults.plus.net
 Chris Parr
 Plusnet Staff
edwardw
done.
64655401
dick:quote
Bjn
I had a similar thing happen Tuesday evening and talked to CS and even with a direct connection to modem from PC (following CS instructions) could not connect. After awhile I could connect via modem but still very slow sub 4mb down ping over 200 on BT speedtest Tap3 test. Raised ticket via members centre. Next morning things back to normal speeds 51mb down and 9mb up and ping of 27. Did a speed test via BT speedtest which support picked up and said they could not find any fault. Not sure is it was something at my exchange Tuesday evening or if PN tweaked something their end but all back to normal. Strange other people here and other forums stating similar experiences this week?
Just thought could it be the gatway we where connected to at PN as it changed when I reconnected my modem and all went back to normal
edwardw
I turned off router/modem for 20 mins this evening after putting up with it all day, and it seems like its back to normal now.
anyone at PN have any ideas why?
dick:quote
Fixes: 5
We may have an issue with 2 end points atm which might have caused it.
Kelly Dorset
Broadband Service Manager
xist
Is there any update on this at all? (and i'm assuming that this would effect a 20CN line?)
I turned my router off last night, and turned it back on again this (mid-)morning and speeds were back to normal again. Went out for the day and now it's back to a crawl...and diagnostics still won't work. In the past i've had BT engineers test my line and all's been fine both times, so i'm assuming that there's a problem with some setting or other regarding my connection rather than anything resolvable by an engineer.
