RDP and Citrix over work VPN has key repeat issues
cedawson
this is my 1st post so apologies if I have the wrong forum or have posted incorrectly.
I use RDP and Citrix over my work's VPN to work from home.  Since switching to Plusnet, I can still connect and see the remote terminal, but now I see key repeats happening on the remote terminal.
Reading the forum's here it seems there have been several issues to do with VPNs.  Most of the posts say the issue was sorted with a tweak on the plusnet side but none of the posts mentions what the tweak is.
Can anyone help me to prevent the key repeats happening?
Thanks in advance,
 Chris
