Quick question regarding recent update order - To PN staff
- Quick question regarding recent update order - To ...
28-05-2014 6:59 PM
I have just placed an order for an upgrade to the fibre unlimited package. (Ticket number #86295165) I forgot to ask at the time whether I will retain my static IP?
I could really do with retaining this as I remote into my network a lot. If this is not automatically setup do I need to contact PN after the install to arrange this?
Cheers in advance,
Damian
Cheers in advance,
Damian
Message 1 of 6
(1,040 Views)
5 REPLIES 5
Re: Quick question regarding recent update order - To PN staff
28-05-2014 7:29 PM
yes, you'll retain it.. or should retain it..
Message 2 of 6
(711 Views)
28-05-2014 8:53 PM
Cheers for the answer, hopefully it'll still be there next week.
Cheers.
adie:quote
Cheers.
adie:quote
Message 3 of 6
(711 Views)
28-05-2014 10:47 PM
You should keep it, sometimes changing product can have the affect of features dropping off.
Although for me that was Max Premium that would drop off every time I changed product, I always kept my IP block.
Message 4 of 6
(711 Views)
29-05-2014 3:21 PM
Yep, you'll be able to keep your static IP.
Message 5 of 6
(711 Views)
01-06-2014 7:15 PM
Cheers guys, looking forward to the fibre install
Message 6 of 6
(711 Views)
