Quick question re router IP address
chuckfrisbee
I would like to log in to my router to check the speed its seeing but I can't remember the IP address to use, as it has been a good 12 months since I've done this.
Can anyone give me a reminder of what this should be please ?
Ta
Fixes: 257
Re: Quick question re router IP address
What is the make of your router?
I suspect it will either be 192.168.0.1 or 192.168.1.1
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
paulby
Some also use 192.168.1.254
However, if you open a command prompt (Start>Run then type cmd) and then type ipconfig /all and look for the entry that says "Default Gateway".  The address quoted is the IP address of your router (generally).
