Questions about ADSL2+ Upgrade
- Questions about ADSL2+ Upgrade
- « Previous
- 1
- 2
- Next »
Re: (Trivial) Questions about ADSL2+ Upgrade
25-07-2012 7:39 AM
Hooray, the Plusnet IP Profile has finally caught-up with the BT one and my connection has been stable for over a day. Below are the basic stats. from my router (Netgear DG834PN)
System Up Time 89:47:10
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 76131 87910 0 122 785 25:44:47
LAN 10M/100M 489293 463439 0 1382 229 89:47:06
WLAN 11M/54M/108M 547918 350582 0 1176 465 89:47:01
ADSL Link Downstream Upstream
Connection Speed 9537 kbps 888 kbps
Line Attenuation 38.5 db 16.6 db
Noise Margin 5.3 db 13.0 db
Message 16 of 19
(352 Views)
25-07-2012 8:01 AM
Oops, looks like my hooray was prematur. My actual download speed seems to have dropped from what it was before the ADSL2+ upgrade.
http://www.thinkbroadband.com/speedtest/results/id/1343199276709420555.html
Message 17 of 19
(352 Views)
Re: Questions about ADSL2+ Upgrade
25-07-2012 12:10 PM
Okay, whatever was causing the problem first thing this morning seems to have dissipated. I'll continue to keep an eye on things whilst the line retrains.
Message 18 of 19
(352 Views)
26-07-2012 10:37 PM
Now about 60 hours on ADSL2+ and my upload sync rate has increased to 1156kbps (and the associated noise margin decreased to 6dB).
Meanwhile my downstream speed is varying in the 9000 to 9500kbps range. My signal to noise ratio is much less stable than it used to be and has wandered down from 6.1 at 20:00 to 4.8 at 22:30.
Message 19 of 19
(352 Views)
- « Previous
- 1
- 2
- Next »
