Question regarding speed capping
spleenharvester
Long story short, the branded Plusnet router was giving us trouble, and after a lot of screwing about I finally have an old DG834G v3 running brilliantly.
Many times during this process the router was obviously connected/disconnected etc over the span of about 5 hours. Is this likely to flag my line up as unstable later on or something?
It's faster than ever right now so appears to be okay with the new router.
Cheers
Fixes: 22
Re: Question regarding speed capping
If its OK now and you avoid further disconnections, then the DLM is not going to get a bad hair day.
Sight of your router stats would be useful please.
spleenharvester
Which appears to be basically the same as before, sans strange wireless dropouts/lag spikes that were on the old router.
Cheers
