Question re ADSL2+
- Re: Question re ADSL2+
Question re ADSL2+
25-05-2012 5:15 PM
I am presently on 21CN ADSL1
How easy is it to move me to ADSL2+ and then, if it all goes wonky, back to ADSL1
If it involves cost to Plusnet getting BT to make the change I won't bother
Message 1 of 6
(1,483 Views)
5 REPLIES 5
25-05-2012 5:32 PM
HI Jim,
I understand that you are on the cusp, but it's not something we'd do for someone to try and then put them back.
Jojo
Jojo
Message 2 of 6
(432 Views)
25-05-2012 5:35 PM
OK - my neighbour across the road - fed from the same pole is on Plusnet ADSL2 with upload uncapped and he doesn't get better speeds than me so lets leave well alone
Message 3 of 6
(432 Views)
26-05-2012 2:43 AM
Hi Oldjim,
As i am on a long line here and also on 20cn, i am interested in knowing what your line attanuation, and sync rate are ?
I would like to pre-empt if it worth considering or not adsl2 for myself.
Paul.
Paul.
Message 4 of 6
(432 Views)
26-05-2012 6:54 AM
Wouldn't setting your router to ADSL1 mode be effectively the same as having it set back to ADSL1 at the exchange?
Message 5 of 6
(432 Views)
26-05-2012 9:37 AM
I am on 21CN - if you are on 20CN (and 21CN isn't available) you don't have the option
Quote from: maximod Hi Oldjim,
Paul.
At present my stats are
Noise Margin: 5.7 dB
Connection Rate: 4832 Kbps
Line Attenuation: 50.0 dB
From memory my neighbour who is on ADSL2 has an attenuation of 51.5dB and about the same speeds but with a slightly lower noise margin
Message 6 of 6
(432 Views)
