Question about connection status system uptime on new router
mkc66
Finally managed to sort out my disconnections with a new router Netgear n300 DGN2200 just got to the 2 days connected when connection time set to 00:00:00 see below at connection Status but when i click show statistics it says 2 days 8 mins but everything else there has also reset to zero assuming this submits clearly I am still connected but why has everything reset to zero and how do I correct this please
Connection Status
Connection Time 00:00:00
Connecting to server Off
Negotiation --
Authentication --
Getting IP address --
Getting Network Mask
Show Statistics
System Up Time 2 days 00:08:11
Port       Status   TxPkts RxPkts Collisions Tx B/s   Rx B/s     Up Time
WAN    Link Dow   0           0               0             0             0               00:00:00
LAN1
LAN2
LAN3
LAN4
WLAN
ADSL Link Downstream Upstream
Connection Speed 4512 kbps 718361 kbps
Line Attenuation 57.0 db 27.0 db
Noise Margin 9.1 db 22.0 db
mkc66
Re: Question about connection status system uptime on new router
also no longer showing attached device  such as laptops iphones etc
mkc66
problem solved maybe a better way to do it but i disconnected and reconnected not ideal but oh well
Fixes: 68
Sounds like your router was having problems to me...
 Adam Walker
mkc66
Thanks Adam thats what I thought in the end, we'll see if it does it again if so it can be returned to store as faulty
Fixes: 68
No problem, I can't directly advise you what to do with a third party router. However a factory reset can resolve a lot of issues like this. If you consider that do make sure you check the instructions or seek advice from the manufacturer.
 Adam Walker
