Question about connection status system uptime on new router
- Re: Question about connection status system uptime...
23-06-2011 7:49 PM
Finally managed to sort out my disconnections with a new router Netgear n300 DGN2200 just got to the 2 days connected when connection time set to 00:00:00 see below at connection Status but when i click show statistics it says 2 days 8 mins but everything else there has also reset to zero assuming this submits clearly I am still connected but why has everything reset to zero and how do I correct this please
Show Statistics
Quote Connection Status
Connection Time 00:00:00
Connecting to server Off
Negotiation --
Authentication --
Getting IP address --
Getting Network Mask
Show Statistics
Quote System Up Time 2 days 00:08:11
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN Link Dow 0 0 0 0 0 00:00:00
LAN1
LAN2
LAN3
LAN4
WLAN
ADSL Link Downstream Upstream
Connection Speed 4512 kbps 718361 kbps
Line Attenuation 57.0 db 27.0 db
Noise Margin 9.1 db 22.0 db
Message 1 of 6
(1,175 Views)
5 REPLIES 5
Re: Question about connection status system uptime on new router
23-06-2011 8:32 PM
also no longer showing attached device such as laptops iphones etc
Message 2 of 6
(599 Views)
23-06-2011 10:05 PM
problem solved maybe a better way to do it but i disconnected and reconnected not ideal but oh well
Message 3 of 6
(599 Views)
24-06-2011 1:09 PM
Message 4 of 6
(599 Views)
24-06-2011 1:33 PM
Thanks Adam thats what I thought in the end, we'll see if it does it again if so it can be returned to store as faulty
Message 5 of 6
(599 Views)
24-06-2011 4:04 PM
No problem, I can't directly advise you what to do with a third party router. However a factory reset can resolve a lot of issues like this. If you consider that do make sure you check the instructions or seek advice from the manufacturer.
Message 6 of 6
(599 Views)
