Question: When was your Tecnicolor 582n (for fibre) delivered?
- Re: Question: When was your Tecnicolor 582n (for f...
18-10-2012 12:15 PM
Don't want it to arrive thursday and post office take it back to sorting office leaving me a card.
Re: Question: When was your Tecnicolor 582n (for fibre) delivered?
18-10-2012 12:20 PM
This is dispatched 1st class delivery at this time, which is touted as 1 to 2 days by Royal mail. We generally advise customers to wait for the third full day after dispatch before contacting us..
Should should mean you would have the router by the end of Thursday, all things running smoothly.
18-10-2012 12:24 PM
Quote from: P Should should mean you would have the router by the end of Thursday, all things running smoothly.
That would be good, thanks for reply.
18-10-2012 2:53 PM
18-10-2012 3:10 PM
Quote from: vultura Don't want it to arrive thursday and post office take it back to sorting office leaving me a card.
IIRC it should fit through a standard letterbox so usually no need for a card from the postman.
18-10-2012 3:13 PM
Quote from: Hairy Although I do have issues with these routers
Thanks for the feedback. Yes, I have been reading about your issues and those others seem to encountering. I seem to recall something about an OR engineer seeing one and installing a Talktalk one that he had on the van instead....
I am almost tempted to bite the bullet (as it were) and buy a new cable router to install and use instead. There is a long thread on the BT forums - http://community.bt.com/t5/BT-Infinity/List-of-Routers-to-replace-Home-Hub-3/td-p/298203, but there are so many recommendations it makes your head spin.
Quote from: w23 IIRC it should fit through a standard letterbox so usually no need for a card from the postman.
Some of the local posties are quite lazy tbh.
22-10-2012 3:45 PM
Quote from: P We would expect your router to be ordered on Monday coming according to our system rules.
Still showing as not ordered.....
22-10-2012 3:47 PM
This is certainly odd. I have ordered this manually and I am looking into why this was not triggered in this morning ordering process.
22-10-2012 3:51 PM
Quote from: P I am looking into why this was not triggered in this morning ordering process.
Thanks, its probably simply down to the way my luck (or lack of) is of late.
23-10-2012 4:05 PM
23-10-2012 5:21 PM
As indicated yesterday, the hardware was not processed automatically in the mornings shipping run. This takes place before 11am and will go in our midday order files to the warehouse.
I hit the manual order button, which does 100% the same thing the script does at 15:46 which was after yesterday order cut-off. These then queue for the next file send to the warehouse.
I have just checked the warehouse inventory and can confirm that the order is in todays dispatches and has already been allocated through the dispatch line, which includes the heat wrap process, postal sticker and then passing along through the Easysetup scanner on the way to the rear of the RoyalMail lorry.
23-10-2012 5:57 PM
24-10-2012 11:29 AM
24-10-2012 11:45 AM
24-10-2012 7:39 PM
Router arrived today, when I arrived home from work in was in the hall. So the package does fit standard letter boxes.
I have it installed now, put my existing DG834GT into modem only modem and so I am connected with the TG582n as I type this.
