Question Thread
- Question Thread
Re: Question Thread
23-01-2009 12:41 PM
Thanks for your reassurance.
I should have read the thread fully,
Re: Question Thread
23-01-2009 7:38 PM
Re: Question Thread
26-01-2009 9:42 AM
Bear in mind that the DLM is far more "intelligent" than it is on IPSM, so whilst there might be a small period of instability, the long run should see the best speed calculated for your line.
Re: Question Thread
26-01-2009 9:49 AM
Any kind of advice on what activities to use the connection for/avoid during the training process so thhat the MSR is as high as possible.
For example, would it be a good idea to use a lot of streaming during that time so that the data rate is fairly stable?
Re: Question Thread
26-01-2009 10:04 AM
It's nothing to do with what you're doing with the internet connection. It's down to the connection synchronisdation and noise margin more than what you do with it.
Re: Question Thread
26-01-2009 10:07 AM
I can't be sure but mine is on well at least my router informs me that interleave depth is 64 DS and
My router is very stable my noise margin is an average 6.8db and my attenuation is 40
interleaving was switched off when I was on 20CN with little or no problems....any thoughts or advice
Re: Question Thread
26-01-2009 12:24 PM
Re: Question Thread
26-01-2009 12:43 PM
Re: Question Thread
02-02-2009 12:13 AM
Hi everyone
As we know people with long lines will suffer signal loss which means higher attenuation hence lower connection rates and speed.
I have looked at various router stats and have discovered that the power of the signal is higher for those with a lower attenuation and in most cases 0.0Dbm for those with high attenuation.
I'm not sure if this is the power pumped out by the DSLAM or the power received by the router.
I realise that increasing the power of the ADSL signal might cause interference on neighbouring lines but increasing the power slightly say 5 db surely wouldn't do any harm. (just a thought)
Re: Question Thread
02-02-2009 1:13 AM
On the other hand for those below the maximum the power can be increased a little, which presumably goes into raising signal content to higher frequencies - which translates into better sync speeds.
Re: Question Thread
02-02-2009 9:13 AM
I ask because mine is showing at 3500 and recently download speeds tests appear to be clamped below 3000 (typically 2800) even though sync is 4384 with interleaving. I have tried at all times of day and evening with no difference.
Re: Question Thread
02-02-2009 9:37 AM
I think profiling on 21CN has to be set manually
BT speed test will indicate the current profile
Re: Question Thread
02-02-2009 9:46 AM
Re: Question Thread
02-02-2009 9:53 AM
Have you tried in both Internet Explorer and Firefox?
If you can't, let me know and I'll see what I can do.
Re: Question Thread
02-02-2009 10:03 AM
