Question Thread
- Question Thread
Re: Question Thread
03-02-2009 10:13 PM
You need to look at the sync speed reported by your router. BT speedtest will determine how your profile should be set: http://speedtester.bt.com/ Compare that with your speed reported on the portal
Can you post the sync speeds reported by your router, the full results from the speedtest, and the current speed reported by https://portal.plus.net/my.html?action=stable_rate
Re: Question Thread
03-02-2009 10:37 PM
my modem says Reserved Bandwidth (kbit/s) up/down = 448 / 7616 which is what the bt test reported.
i know my profile is set to 6500k but i cant find this anywhere on my modem
is this what you mean by sync speed? sorry this is new info for me...
and for the admin staff if you could work your magic on my line i'd appreciate it, thanks
Re: Question Thread
03-02-2009 11:14 PM
The sync speeds quoted suggests you are not on 21CN. In your posts you referred to "modem" as the source of the stats - did you really mean modem or is it an always-on router? What make/model is it? Just wondering if it supports ADSL2+.
Re: Question Thread
03-02-2009 11:29 PM
Re: Question Thread
03-02-2009 11:48 PM
Re: Question Thread
04-02-2009 12:20 AM
It doesn't look as though the v3 or v4 models support ADSL2+, but the CLI manual for the v5/6 mentions ADSL2+.
Re: Question Thread
04-02-2009 8:19 AM
Re: Question Thread
06-02-2009 10:06 AM
i checked my speedtouch router and its a v4. the latest speedtest reports the same download speed but my upload speed is 50% higher. i have a netgear router, im gonna try it and run a speedtest and post results soon.
thanks for all the replies.
Re: Question Thread
06-02-2009 10:21 AM
Re: Question Thread
06-02-2009 10:46 AM
Re: Question Thread
06-02-2009 11:26 AM
ADSL Firmware Version 1.00.09.00
Modem Status Connected
DownStream Connection Speed 8128 kbps
UpStream Connection Speed 1024 kbps
i tried to go to the bt speedtester but error message came up. now i have to wait for 3 hours, but i did notice during the test that my profile has changed from 6500K to 8000K.
surfing the web feels so much faster and on my xbox360 i noticed ping drop from 55 - 70ms to 30ms on a game i play with friends(castle crashers).
im still having trouble updating router...
Re: Question Thread
06-02-2009 5:39 PM
Just got switched on today. Using the same router but V1.02.08 firmware
and experiencing similar speeds.
Previously on 8mb business at 20/1
Marked improvement with uploads but downloads has hardly improved
DownStream Connection Speed 8610 kbps
UpStream Connection Speed 1119 kbps
Moderator's Note: Full quote of previous post removed since it is unnecessary.. David (spraxyt).
Re: Question Thread
06-02-2009 6:27 PM
G.DMT wrapped up in ADSL2+ (well that's how it seemed to me anyway).
I had this problem - Download was also exactly 8128Kbps
Re: Question Thread
06-02-2009 6:29 PM
Quote from: axisofevil Check the really detailed stats - does it look as if you are running as a
Sorry - how do i do that ?
Re: Question Thread
06-02-2009 9:03 PM
To check go to http://kb.netgear.com/app/products/list/p3/161and select your model and version.
