Question : New Fibre Install - what's the engineer for?
redlegoman
Just a quick question. I've ordered an upgrade from ADSL2+ to Fibre, and the engineer is coming on Friday to "install" it. What is the engineer actually going to do other than deliver and plug in the supplied router?
Fixes: 162
Re: Question : New Fibre Install - what's the engineer for?
They'll do some work at the cab/exchange and then change your faceplate over to a filtered fibre socket along with installing the modem.
 Chris Parr
 Plusnet Staff
redlegoman
Righto. And if I've already changed my faceplate, which I did a few years ago in order to eek out a few more K from my ADSL?
Plusnet Alumni (retired) LinnPlusnet
The engineer will still require access to the property to install the modem and test your connection.
If you've ordered a router from Plusnet then this should arrive a couple days prior to the installation date.
