Question #85864399
- Question #85864399
Re: Question #85864399
04-07-2014 10:14 PM
Make sure no one else is using your network at the same time as running the test.
05-07-2014 10:10 AM
05-07-2014 10:16 AM
It might be worth considering getting a static IP for a one off £5...it saves having to create a new monitor each time you lose sync.
05-07-2014 10:50 AM
05-07-2014 11:01 AM
05-07-2014 12:03 PM
05-07-2014 2:24 PM
On the TBB graph, it looks like something was running around 5am.
05-07-2014 6:57 PM
06-07-2014 8:02 AM
The speed test warned me that I have a variable streaming result and linked to me to this information:
Our speed test carries out two main tests, the first which is the tbbx1 result in your case looks to be a lot more variable than the HTTPx6, suggesting congestion at the ISP or over the WiFi link in your home.
As I am the only one on the network at this time I think we can safely assume its the former
06-07-2014 8:04 AM
08-07-2014 5:11 PM
10-07-2014 9:54 AM
10-07-2014 9:57 AM
10-07-2014 10:44 AM
10-07-2014 6:50 PM
