Question #78089694 No response
- Question #78089694 No response
05-12-2013 8:40 PM
Re: Question #78089694 No response
06-12-2013 8:41 AM
06-12-2013 10:39 AM
I've checked over your connection and can't see any issues. Your download speed and profile look ok.
Downstream Speed 66.7 Mbps
Upstream Speed 20.0 Mbps
Profile Name 40M-80M Downstream, Interleaving Low - 10M-20M Upstream, Interleaving On
Are you connecting over a wireless or wired connection?
06-12-2013 10:43 AM
06-12-2013 11:18 AM
06-12-2013 12:05 PM
this is what bt site checker i can get
79.9Mb*
Download speed
20Mb*
Upload speed
by entering my phone number
06-12-2013 12:46 PM
The speeds you're getting look pretty good and I wouldn't worry too much by an increase of 8ms in your ping, it wont affect anything you do on the Internet.
All Fibre circuits have DLM on them, this cannot be removed.
06-12-2013 1:04 PM
i have BT Openreach Modem Router FTTC VDSL Hawaeii HG612 thats 3 years old one
06-12-2013 2:17 PM
Your speeds have decreased because the DLM has determined it needs to decrease your speeds to improve the stability of your line. You are currently on a 64400 profile on our side, which we changed you to this morning after BT informed us of a profile change on their side. This is slightly under your estimate of 68Mbps.
It's probably nothing do to with your modem, more likely to be weather related, or perhaps some crosstalk from additional people getting fibre installed from your cab.
Ex-Broadband Service Manager
06-12-2013 2:36 PM
http://www.speedtest.net/result/1902292967.png that was the speed when i was with them for 3 years like that
when do you think the DLM will kick in again to test high speeds again?
07-12-2013 4:35 AM
09-12-2013 10:04 AM
