Query about PPPoE and 21CN
- Query about PPPoE and 21CN
17-04-2009 9:58 PM
Having connected successfully to the ADSL2+ trial (no speed gain, but what the hell...) I've been playing!
After stumbling over a nugget of info that stated that the 21CN is PPPoE compatible, I tried connecting with PPPoE with LLC Encapsulation. It worked!
The reason I tried is it lets me use my exisiting DG834G as a bridge to my PPPoE Time Capsule, which now looks after the connection happily for me. It seems to work quite nicely.
And so, to the question! Is PPPoE a BT / PN supported (or at least allowed) way of connecting? Is it even going to be the only way in the future (a post I read said that their exchange wouldn't work with PPPoA anymore, but this may have been an LLU provider)?
Hope that's helpful / interesting for someone!
Message 1 of 7
(3,019 Views)
6 REPLIES 6
Re: Query about PPPoE and 21CN
28-04-2009 9:26 PM
Good to know. I use to run my connection this way before moving on to the trial and I will revert back after the training period as I lose the modem status page when I place it into bridge mode.
Message 2 of 7
(931 Views)
28-04-2009 9:46 PM
PPPoE is definitely a BT-supported protocol on ADSL1 (I used it for exactly the same reason - turning a Linksys router in to a bridge to use with my Time Capsule), and I see no reason why it shouldn't be similarly supported on ADSL2+, as the ADSL 'type' only affects the sync, whereas PPPoA/E relates to the actual data connection.
Message 3 of 7
(931 Views)
29-04-2009 9:40 AM
I'd be inclined to say that if it works, it works and we're not going to stop you from connectiong over PPPoE.
However, we will always recommend that you use PPPoA.
Message 4 of 7
(931 Views)
29-04-2009 5:48 PM
Just curious, but what's a time capsule?
Message 5 of 7
(931 Views)
29-04-2009 5:59 PM
This. It's a useful device - and, ironically (considering Apple aren't well known for their routers), the most stable router I've yet used.
Message 6 of 7
(931 Views)
30-04-2009 3:36 PM
Hi everybody
I was under the impression that PPoE is the protocol used by cable based ISP's
Is there any advantage in using PPoE rather than PPoA?
Message 7 of 7
(931 Views)
