Queries regarding my switchover
- Re: Queries regarding my switchover
28-03-2013 1:52 PM
Switching my BB to plusnet from bt, last communicae was that switchover should complete march 29th, with a minor downtime. Currently my BB is down and has been since before 7am this morning the 28th(so up to now that's about 7 hours and counting) is that normal? and I'm also a little concerned that the 29th is also a bank holiday, any idea if this going to affect the switchover?
Message 1 of 5
(784 Views)
4 REPLIES 4
28-03-2013 1:59 PM
have you changed to the Plusnet router or changed the details in the existing one
Which lights on the router are green and which are red
Message 2 of 5
(395 Views)
28-03-2013 2:12 PM
I've just taken a look at the order on our suppliers systems which has completed. I've manually activated your account on our systems so you should be up and running now providing you have connected the router we have sent you?
Message 3 of 5
(395 Views)
28-03-2013 2:25 PM
Well I'm in work till later on this eve, so I'll connect it all up when I get home as the mrs' wouldn't have a scooby!
P.S. Thanks for the quick replies.
Message 4 of 5
(395 Views)
28-03-2013 2:30 PM
No problem.
I'm sure you'll get that connected up when you get in. Any problems, let me know and I'll do anything I can to help
Message 5 of 5
(395 Views)
