Qube Engineer made things worse
drbillsw
For the 3-4 weeks I have been getting speeds close to and below my guaranteed speed. I pay for a 36Mb/s line, I am guaranteed 24Mb/s down and should get 6-7Mb/s up.
For the last few weeks I have been getting 14-24Mb/s down, 4Mb/s up. Today the Qube engineer came changed the socket, suggested I switched the BT home hub router to the Plusnet home hub one and I’m now getting 10-14Mb/s down and 0.3-0.4Mb/s up.
Frustrating…
11 REPLIES 11
Legend
Fixes: 255
Re: Qube Engineer made things worse
@drbillsw PN staff are unlikely to reply at a weekend so:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Mav
Fixes: 515
Moderator's note(s):
Thread moved from Full Fibre to Broadband.
Forum Moderator and Customer
drbillsw
I'm not sure how to attach pictures to the topic but I have put them in my public images at the following link:
https://community.plus.net/t5/media/v4/gallerypage/user-id/113724/album-id/33946/tab/albums#.YuVpYp0...
Not sure why it is suggesting my maximum possible speed is 17Mb/s as that is lower than I have been getting for two years (30 Mb/s+) and less than I was guaranteed both times I have renewed.
I can't try the silent phone test as I haven't had a landline phone for over a decade haha.
Legend
Fixes: 255
@drbillsw Unfortunately, those images are a little blurred, but from what I can see, I would suggest you raise a fault via: https://www.plus.net/help/report-a-problem/broadband/
Unfortunate you don't have a phone - it is a very useful test implement on ADSL/VDSL lines.
drbillsw
Thanks, is there a reason why the BTW test is suggesting my line is a 17Mb/s capable line when this is lower than the estimate the last 3 years and lower than my lowest guaranteed speed?
Legend
Fixes: 255
Yes - you have obviously had the problem for a while and the DLM equipment in the cab has tried to compensate by lowering your speed in an attempt to get some stability.
Report the issue as I suggested earlier.
Fixes: 418
@drbillsw
 The first screenshot shows that yesterday BT measured your speed at 34 Mbps down and 7.2 up. Are you testing over wireless or an Ethernet cable? Have you tried a factory reset of your hub by pushing a paperclip or similar in the Reset hole, keeping the switch closed for about 30 secs?
Do you have a static IP address?
Fixes: 1,600
I'm really sorry to see you're having speed issues.
The BTW performance result is showing a maximum achievable of 17mbps, because that's what your router's in sync at.
I've tested your line today and the tests are showing a high resistance fault as well as a "Dis In Network" which would suggest there's a disconnection or break somewhere along the line, causing these issues.
I've raised this to Openreach and I've been given an estimated response time of by 03/08/22 23:59:59 for an engineer to investigate further. We'll update you via the ticket logged Here as soon as we know more.
Legend
Fixes: 255
So that 'Dis(connect) in network' and HR fault are the causes, the Qube engineer visit achieved nothing?
Fixes: 1,600
It seems that way but we couldn't have known as our tests didn't pick up on these faults previously.
Legend
Fixes: 255
Fair enough. 😀
