Puzzle time!
- Puzzle time!
- « Previous
- Next »
Re: Puzzle time!
15-07-2012 4:18 PM
Can I suggest you manually set the router time & date as I thought SNTP was the connection computers/routers use to connect to "time servers" ~ just a thought???
Message 31 of 38
(489 Views)
Re: Puzzle time!
15-07-2012 5:34 PM
Where did this 198.18.1.8 address come from? I believe it's totally erroneous. Whether it's causing the problem I don't know.
Message 32 of 38
(489 Views)
Re: Puzzle time!
15-07-2012 5:49 PM
Quote from: Anotherone Where did this 198.18.1.8 address come from? I believe it's totally erroneous. Whether it's causing the problem I don't know.
Well maybe this throws some light or not as the case may be???
http://networktools.nl/whois/198.18.1.8
clipped info from that page
Comment: This block has been allocated for use in
Comment: benchmark tests of network interconnect
Comment: devices. This range was assigned to
Comment: minimize the chance of conflict in case a
Comment: testing device were to be accidentally
Comment: connected to part of the Internet.
Comment: Packets with source addresses from
Comment: this range are not meant to be forwarded
Comment: across the Internet
Edit ~ yup, SNTP are time server type locations as mentioned here http://en.wikipedia.org/wiki/Network_Time_Protocol
Message 33 of 38
(489 Views)
Re: Puzzle time!
15-07-2012 6:18 PM
Ok, I've just read through the thread again and this is a mystery, in addition to which because of my previous post, I suggest the sensible option at this point would be to do a full factory reset and make no changes to any settings other than entering the broadband username and password.
Then see what happens.
Just to clear up another point, I was confused buy this discussion about DNS addresses -
212.159.6.9 & 212.159.6.10 & 212.159.13.49 & 212.159.13.50 are ALL valid Plusnet DNS server addresses and have been for some many years.
Message 34 of 38
(490 Views)
Re: Puzzle time!
15-07-2012 6:45 PM
Hi all,
Had a phone call from the lovely JoJo and she will try and sort it out. Thanks everyone for the advise. I've been through all the settings again and still nothing. But I'm sure it won't be long before I'm up and running again. The only forum piece similar to mine is this: http://forums.thinkbroadband.com/dslrouter/3551461-really-confusing-sync-problem.html?page=4&view=co...
Many thanks,
Stephen
Many thanks,
Stephen
Message 35 of 38
(490 Views)
Re: Puzzle time!
15-07-2012 6:49 PM
Have you tried a factory reset of the 582n? You could be messing around for ages if you haven't done that!
Message 36 of 38
(490 Views)
Re: Puzzle time!
15-07-2012 6:54 PM
Yes I have and it makes no difference.
Message 37 of 38
(490 Views)
Re: Puzzle time!
15-07-2012 7:03 PM
Quote from: Routefinder Just to ask those who know more but in the case I mentioned with disabling IPv6 like I had to do has anyone else noticed this??? In case I did not mention it I run W7 Pro 64 bit on the PC in question and the motherboard has a Gigabit ethernet port........in other words is it the "connectivity settings" of the ethernet connected PC that is the source of the problem rather than in absolute terms the router settings???
I've not had to do that with my w7x64 and tg582n with the 10.x demo firmware
Message 38 of 38
(490 Views)
- « Previous
- Next »
