Punishment ??
- Punishment ??
- « Previous
- 1
- 2
- Next »
Re: Punishment ??
29-03-2016 1:47 PM
Re: Punishment ??
29-03-2016 1:51 PM
WAN PPPoA 99919 117043 0 28274 33753 01:14:00
LAN1 Link down 56594685 57806916 0 1242 826 620:11:05
LAN2 100M/Full
LAN3 1000M/Full
LAN4 Link down
WLAN b/g/n 145M 38315552 28418314 0 221 629 620:10:34
WLAN a/n 300M 3324139 1155775 0 868 159 620:10:28
ADSL Link Downstream Upstream
Link Rate 1917 Kbps 446 Kbps
Line Attenuation 69.0 dB 43.8 dB
Noise Margin 6.5
Re: Punishment ??
29-03-2016 5:07 PM
Re: Punishment ??
29-03-2016 5:09 PM
Re: Punishment ??
29-03-2016 5:46 PM
Re: Punishment ??
29-03-2016 6:46 PM
Your connection speed is back to just over 1900, it might take a while for Plusnet to reset your profile, what does it show here under "Current Line Speed" ... https://portal.plus.net/my.html?action=data_transfer_speed
If that looks correct, I think it should be something like 1.6 or 1.7 meg, then you might have to reset your connection to bring that into effect. To explain, BT sets a speed inside their network based on the speed your router connects at, then Plusnet get that speed reported to them and they set a data rate of their own. You won't get the benefit of any speed increase until that's shown on the Plusnet current line speed.
Re: Punishment ??
12-04-2016 11:29 AM
Well I had a BT visit and as my line was working as wellas expected he agreed not to alter it as it was stable
System Up Time 953:48:47 | ||||||||||||||||||||||||||||||||||||||||||||||
Re: Punishment ??
12-04-2016 11:32 AM
Much better
1. Best Effort Test: -provides background information.
Download Speed | |
1.88 Mbps |
0 Mbps | 2 Mbps Max Achievable Speed |
Download speedachieved during the test was - 1.88 Mbps For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps. IP Profile for your line is - 1.92 Mbps |
Upload Speed | |
0.36 Mbps |
0 Mbps | 0.45 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 0.36Mbps Additional Information: Upstream Rate IP profile on your line is - 0.45 Mbps |
- « Previous
- 1
- 2
- Next »
