Pulling my hair out over PlusNet lack of support.
KitKite
Enter
28 REPLIES 28
Fixes: 334
Re: Pulling my hair out over PlusNet lack of support.
@KitKite What was the date of the Help desk information in your above post? The data on that indicates that you do/did have a problem when it was grabbed - your D/S noise margin is way too high, and unless you have turned the router off, you had DSL drops previously, which will have caused the banding.
To be honest, I would accept the suggestion to get a new Hub - the 2704 is ancient, and could be dying, which MAY explain your errors I mention above.
Longliner
All Star
Fixes: 8
Don't you think it's rather unfair to lambast Plusnet just yet? Their suggestion of a new router is just common sense as the 2704 was great for its day but is now well past it, like myself! You've skipped the Hub One and I think you will be pleasantly surprised by the Hub Two.
KitKite
The router has been rebooted after the Broadband failure at Christmas. It was left on for several weeks. It increased to a max download of 6655. The max limit of the lower banding is 6655. Is that a coincident?
Also how long should the broadband take to change to the next higher banding profile?
Fixes: 334
@KitKite Can you post your current Help Desk?
KitKite
Thanks for the reply.
My frustration is that PlusNet has not or avoided making any comment or apology to the system failure in my area at christmas.
My modem is stable at the very top of a banding profile at 6655. Can someone explain why at exactly 6655 and not say more or less.
It does not change. Even after a modem reboot. Its like the line capable of going higher but can't because its locked/capped to that profile. If a line is set to a banded profile can that line go higher?  And how long will it take to move to a higher band?
I live in the South London/North Surrey area. How can i find out why my line dropped to a unusable speed of way below 1Mbps over the Christmas period?
BTW. My service is not a fibre.
Fixes: 334
I am aware you are on ADSL - your use of the 2704 proves that, as does the data contained in the screenshot. Now can you do as I asked and post your current Help Desk?
KitKite
(Sorry if this is a 2nd reply i think i didn't send it???)
Yes Sure.
What do you mean '...current helpdesk?' Is it the PlusNet support question number or the modem stats or some thing else? Not sure
Fixes: 334
The modem stats- as in your first post, in the form of the bit that starts ' Your Plusnet adviser may ask you for the following information:'
KitKite
1 - Product name:    Plusnet Router
2 - Serial number:    N7171081B005543
3 - Firmware version:    7.275.17_F2704N_Plusnet
4 - Board version:    F@ST2704N
5 - Mode    ADSL
6 - Uptime:    2 days 03:14:22
7 - Data rate:    1180/6655
8 - Maximum data rate:    1180/10872
9 - Noise margin:    5.4/11.7
10 - Line attenuation:    22.2/42.5
12 - Data sent/received:    616.3M/1.9G
20 - Broadband username:    t@plusdsl.net
21 - Wi-Fi network/SSID:    PLUSNET-TPX7JR
22 - Wi-Fi connections:    Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS disabled
23 - Wi-Fi security:    WPA2
24 - Wi-Fi channel:    10
25 - Firewall:    Default
26 - MAC Address:    f4:6b:ef:8d:e7:4b
27 - Software variant    Version 1.0
28 - Boot loader:    7.275.6
Fixes: 334
In the absence of any further information, and providing you haven't turned the router off in the past three days, you have a DSL connection issue which - whatever Plusnet say - requires investigation.
Fixes: 1,639
@KitKite - looking into this, the MTBE (Mean Time Between Errors) is 1 which means within the last 24 hours, the line has been producing errors every second, and currently at this moment, there are 132 errored seconds.
This would very likely be causing the banded profile of 'WBC 3M - 6M Medium delay (INP 2) 6dB Downstream\, UC Low delay (INP 0) 6dB Upstream (ADSL2+)', highlighted the significant part of the profile.
I would say that removing the banding without first addressing the underlying issue won't be wise, as a higher speed would likely mean more errors produced more frequently then the connection suffers.
Errors are often caused by routers which are starting to fail, but microfilters or internal wiring could also play a part, so might be worth troubleshooting: Broadband problems and how to fix them (Fibre with phone) | Help | Plusnet
Fixes: 334
@Gandalf - This is an ADSL connection. 😉
Fixes: 1,639
Good spot, but it looks like ADSL and FTTC troubleshooting are compressed into one support article, with the URL showing it as fibre when in reality it can be used for ADSL as well. More specifically, the above link was from Broadband problems and how to fix them | Help | Plusnet selecting the 'Packages with a home phone line' option.
Fixes: 334
OK. Not splitting hairs here, and appreciate your support, @Gandalf , but a couple of things in that Help Desk shot stand out to me and suggest it is a OR network issue (1) the 'Uptime' figure and (2) the horrendous D/S noise margin. It's a long while since I've been on ADSL, but if those figures showed up in my Help Desk, I'd be screaming blue murder.
