Ps4 strict nat
boatman1961
Ps4 strict nat
Just come over from bt told was better for online gaming .on Bt. the gaming was rubbish but had nat type open .I'm using  the standard router( technicolor ) the ps4 is nat type2 40+ meg download 12+ upload low ping was told to open the ports so I have still strict.trying to play cod is hopeless it's like I'm half a sec behind plus net tech support say not able to help anybody out there got any ideas  or am I stuck with this for 18 months
ghos7em1
Re: Ps4 strict nat
you can use any cable router m8 even ur bt hh  Smiley technicolor routers not good for gaming even with open nat
ghos7em1
Re: Ps4 strict nat
use dmz your nat will be open but only use dmz for consoles
