Prompts for password
chrisco
Hi all, not sure if this is the correct forum to be asking this but here goes, I have been prompted all day for my network password (authentication?) all I do is click ok, the message box closes for a while but then pops up again after about an hour or so. Is this anything to do with the email problem as I'm also having problems receiving mail (via Outlook) even when I request a send/receive. I can still access the net & have no problem connecting. Any ideas anyone?
18 REPLIES 18
coastergrotto
Re: Prompts for password
I would imagine it is. Read this thread:
Email authentication
chrisco
Yes I did see that, so it looks as though I've been having the same problem. No info in service status messages though which is the first place I looked in, maybe they need updating?  Roll_eyes
pierre_pierre
James
Chris - Those issues should still be fixed.
Are you still unable to log in to webmail?
Oldjim
Resting Legend
Fixes: 63
and despite the latest statement I have just had another rejected login by the email server
James
Jim - Thanks.
Is it intermittent or permanant?  Do you get the same in webmail & telnet?
Oldjim
Resting Legend
Fixes: 63
Intermittent - as that was only one of 4 checked mailboxes and the other three worked.
All worked next time.
I have also started getting this when clicking on a link in the forum
Fixes: 1,483
I get that when I hold the 'alt' key down a little too long after alt-tabbing into my browser..
artmo
Aspiring Champion
I'm being asked for my password each time I log in to collect my mail.
James
Does it then allow you to receive your email or is it just bombing you out each time?
artmo
Aspiring Champion
No James I don't get bombed out and i can download my email.  Still being asked for password this morning though.
reserved
Don't know if this is linked but some of us are unable to get new emails through Outlook Express this morning, see http://forums.thinkbroadband.com/freenetname/f/3648443-email-problems.html
chrisco
Thanks for the replies. @ jameseh I have just logged into webmail & Outlook is downloading my messages ok & the password prompt has stopped prompting! Everthing seems to be running smoothly.  Smiley
reserved
Quote from: chrisco
You're lucky - Madasafish, Waitrose & Greenbee emails are still down  Angry
